I have a new tom tom one v4 which is frozen in op mode?
Was chargimg vis USB lead and the screen is stuck in a black technical data page with the clock still working. I have tried to hold the on/off button for 15 secs but nother happens??
Try this: On your Android Smartphone, download the "Facebook" app from Google Play. Run the app, when the app asks for them, enter your login credentials for Facebook and voila - you're in. Good Luck!
3. Look closely at the GPS output that is displayed in the View Status
menu. Data should be flowing even when the GPS receiver has not locked
in the position.
The data string that begins:
GPGSV... is "bad data" because the receiver has not locked
into the satellites.
Whereas:
GPGSA... is "good data" indicating that the receiver has
locked into the satellites. Remember - "A-Okay"
4. Once the data is flowing, go outside away from buildings, select
the Satellites tab (Tools>GPS Status>Satellites), and watch
the satellite signal strength
If the problem is only with the Black Ops game it could mean that the the game paly data is corrupt. Start by deleting the saved game data and the file data for the Black Ops game and if that doesn't work try doing a system restore. NOTE: A system restore will delete all other game data. I recommend backing up your system onto a usb flash drive.
The problem is either the color wheel or dmd board. Both parts are expensive so I would recommend contacting a Samsung authorized repair center. You can call 1-800-samsung or go to samsung-usa.com to find a service provider.
Hello megbert,I own a TomTom also and have had your same problem before. I have listed the procedures from TomTom Home. First try a soft reset (Reset button is located at the bottom of the TomTom device next to where the DC plug plugs in). Make sure your batteries are charged up or the USB is plugged in.
If your device is not starting up properly, follow the steps below:
If you have backed up your TomTom to your computer, then you can reinstall the TomTom application from your backed up dataIn rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
I have had a frozen screen on my TOM TOM - I solved this problem by resetting the TOM TOM. I did this by pressing the pinhole reset buttom on the back of the unit - labled RESET.
