The phone is currenty in french and i want to change it to english
SOURCE: change language
check in the settings,then language option and see if english is there,if not you'd need to change the firmware
SOURCE: How do I change language of my htc touch to english ??
by vising the given website www.htc.com pls furnish the proper model no of your mobile then u can automatically download the manual frm where u can know the procedure to channge language
SOURCE: language setting on htc touch phone
hi, i bought a htc touch phone in German language. would it be possible to change it to english.
SOURCE: changing language from chines to english for HTC P3450
Would you love a HTC Touch Diamond, but afraid it wont work in your
language? Never fear, Panosha from XDA-Developers have the solution.
Simply change the value in this registry key HKEY_CURRENT_USER\MUI\CurLang
from Hex 409 (english) to any other localization value (found in this list ). 408 is Greek, 404 is traditional
Chinese, 40E is Hungarian and so on.
Tip via XDA-Developers.com
SOURCE: htc 3600 problem in chang language i like to
Hi, To change the language on your HTC P3600, this is what to do. Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings." Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit." Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you chose.
