SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
SOURCE: lg ductless air conditioner is coming up with code ch 5
Communication between indoor PC and outdoor PC missed. Check that all connecting cables are good.
SOURCE: I have error code ch 09 displaying on my
Hi, The error CH09 on LG airconditioning units is an EPROM checksum problem "EPROM Checksum Mismatch". This most likely means that the EPROM "Electronically Programmable Read Only Memory" on the control PCB has failed. You should be able to get a new EPROM from LG and hopefully it wont cost much. Depending upon your location I would suggest using google to find LG air Conitioning spares (You'll need the exact model and part number) Hope this helps
