For windows 7 professional
Have you upgraded the OS? Audio drivers can be found here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=447348&prodTypeId=321957&prodSeriesId=447371&swLang=8&taskId=135&swEnvOID=2094
SOURCE: sound device problem
The problem is the software driver that will make your sound device is not installed.install the device driver.this wiil cure the problem.
SOURCE: how do i install audio output device
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down.
SOURCE: Sound Drivers for Windows Xp
DEAR SIR,
I need Sound Drivers for Conexant HD Audio Smart Audio 221 Supporting OS should be Windows Xp Professional. MY laptop Model Compaq Presario c700. Kindly help me Pleaseeeeeeeeeeeee
install
EMAIL ADDRESS [email protected]
SOURCE: no audio output device installed is showing and no sound is coming.
if you have xp or vista go to device manager area and uninstall the device then click find new device it should sort the drivers out for you to work again
if it dosent work for you get back to me and ill see what can be done for you
SOURCE: Audio drivers for HP compaq nx7010 with Windows 7
This WEB site can supply the Windows 7 drivers, please click on this link :-
http://www.user-guides.co.uk/cddownload/HP/HPCompaq/HP-Compaq-nx7010-Windows-7-Driver-Recovery-CD-Restore-Disk-313489.html
