SOURCE: all dash warning lights came
Hatterasnc,
You're alternator has gone bad and the vehicle was running on battery power. The "clicking" sound is your now dead battery that does not have enough power to turn over the starter. You might also want to check your power steering pump for leak. This is a know problem with early LS400s and will most likey be the cause of the alternator failure. I just dropped $1050.00 to fix the very same promblems you have.
SOURCE: 2003 VW Golf won't start - battery was charged
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
SOURCE: Honda Civic Dead Battery then won't start- Kill switch?
You must fully charge the battery again , injection models are a pain
SOURCE: Car wont start, no clicks no sound
make sure you have power getting to your starter when you crank. check the small nut on the starter. should have 12 v or very close to it. this will tell you if your getting power to the starter or if somethign before the starter and something maybe with your anti theft system or not. its hard to say online cause of that anti theft. doest the light flash at all? the anti theft light?
if your getting power to the starter when you crank make sure your getting good power to the starter by turning on the head lights and see if they dim. a good starter will cause the headlites to dim when attempting to start. if nothing dims check connections. or assume bad starter motor. make sure your also getting power to the main starter stud as well.
good luck
michael
