Multi-Diag Access J2534 has the function for air condition, such as Diagnosis of cooling electronic,
Reading settings cooling circuit,Test servo actuators
http://www.careucar.com/wholesale/[email protected]
SOURCE: My AC blows hot air out the driver's side and cold
My 02 Century has dual temp controls . One for driver for passenger. Make sure you don't have the dual climate enabled and just set for heat on your side and AC on the passengers
SOURCE: on 2002 buick regal ac problems. Tried a jumper
Does the system have a leak? If it does, then the computer might have set a low freon code that usually does not turn on the check engine light by itself. If this occurs, the code will have to be erased before the compressor will run. The computer does this in order to protect the compressor so that it cannot run without enough freon in the system. Once you correct the amount of freon in the system (if it needs it), reset the system and see if the compressor will run. Some parts stores have the ability to erase codes and will usually do it for free. I hope this solves your problem. It's definitely not good to have AC problems this time of year. Thanks for trying Fixya.com.
SOURCE: compressor keeps kicking off 1999 Buick Century AC
Your ac system is most likely low on freon, or the cooling fan is not working.
When you turn on the ac the cooling fan should stay on.
If it stays on then you are low on freon.
Should be one oring or gasket on each line - the bolt is probably 20 or 30 ft lbs, enough to be tight without stripping it much like an engine bracket.
