My computer turns on Shows Windows XP and then goes to Checking files system on D: The type of the file system is FAT32 One of your disks needs to be checked for consistency. You may cancel the dis check but recommended you continue Windows is verifyinng files and folders It will go to 59 percent completed and stop? Help.........I have fallen and can't get up BJtheDJ
At startup, hold down F8 key. select safe mode start. allow windows to guide you from there. if no-go, then repeat but choose dos prompt only, then insert a win 98 startup disk and run scan-disk on your drive. if no-go, in worst case, try to delete the pagefile.sys file from dos prompt (you may need to change file attributes from read-only and hidden and system to toggled-opposite-read, not hidden, not system). and repeat above steps
