When I recall the message it seems to be there, but when you call the line, there is no greeting. An operator or someone says enter your area code and number and then she asks for your password.
SOURCE: Need manual
If you haven't received an answer to your request, You can find the manual at the following url:
http://www.florenceinc.com/en/documentation.php
If it doesn't take you right to the correct page, enter M5316 in the search window and it should find it for you. I tried to upload the document but there was no way to do it. Hope this helps.
SOURCE: how do i record the main greeting on a comdial edge 120
I just went thru this.
Push the Voicemail button, hit # until it asks for mailbox #, then hit 70 for password. Wait for main menu, then hit 3 for options. Then hit 2 to record your greeting. Now the tricky part,,, I don't know if these are all programmed the same way, but it will ask for the number of the box you wish to change, ours is 800, then follow along.
good luck!
What I'm trying to find out is how you can import a prerecorded message (mp3) as your greeting.
SOURCE: how do you record greeting? i lost my manual for kx-tg9331t
Check on the web page for panasonic .
Type in your unit number after you get to the manual area.
SOURCE: NEC Phone System - Setting Up Operator's Voicemail
i need u to help me set up the vmail on my phone
SOURCE: I have mistakenly changed the password to the CCR
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
Testimonial: "The solution was right on! I was able to reset the password and update the greeting message. Thanks for the help."
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
