SOURCE: Gas oven - - melted plastic inside
You can remove the bottom oven panel and look under it. All you have to do is remove the oven racks and locate the screws that hold the bottom panel in place. MOST ovens only have two of them. Once you have the crews removed, the panel slides back a bit, then lifts up. If there are any heavy deposits of melted plastic, remove it like you did before. Any residual material can be taken off with some fine emery paper. Wear a dust mask and vacuum all the dust out of the oven. DO NOT use this method on the oven wall as it may scatch it. This is only for anything that may have dripped below the oven pan. You may have an odor to the oven for a while, but as long as you have nothing else melted inside this should go away. Try running it on a cleaning cycle AFTER you've inspected the oven & cleaned out the remaining plastic. This will burn off anything left behind. I hope this helps you.
SOURCE: Melted plastic lid in oven - how can I remove it
Any oven cleaner, like easy off will work on this but it may take more than one application. You can actually begin with your hair blow dryer and a putty knife by heating the plastic up enough to scrape most of it off. Then let the oven cleaner do the rest.
