I have tried: - taking apart foot pedals to see if there are any loose wires, - replacing RJ11 cable - settings in Forza 2/ F1 2011
SOURCE: Racing wheel setup
OK, at least for my issues, after talking to MS support ...
Here was the issue with the Setup disc (Forza Demo): If it jumps into the demo ... the XBOX DOES NOT need to be updated.
As for not connecting to the XBOX (Sync'ing up the controllers) ...
You need to press the SYNC (located by the memory card slots)Button BEFORE you PRESS the SYNC button on the wheel controller. Once you do that (a step that is not clearly pointed out in the stupid an poorly written manual) all worked asa expected. A Simple hook-up procedeure that took 2 days because of a step that was not pointed out or not made obvious to the XBox Parents and non users.
After fiddling and doing a bit of research, I found out that the xbox360 steering wheel takes the strait RJ11 cable and not a cross over RJ11 cable. I have yet to get the cable, but I believe this may be the solution
