I unplugged the tv from my bed and took it down stairs to plug it into my daughters bed room. When I did I saw a blue spark shoot out the back near where the power plug is. it then tripped the breaker in the house panel. i tried to plug it in again and the breaker tripped. Any ideas on what it could be?
A nasty short somewhere or wrong voltage to set---do not keep plugging it in and tripping the breaker--in fact do not plug in at all until a technician examines it(tell him/her what the issue is).
To answer the question here: Dead short on or across the AC voltage line inside the set most likely of primary side of power supply.
SOURCE: What is the Uverse remote code for Apex LD3249 TV
hi! i have here one code for your APEX tv, just try it 1088, hope this helps!!!! goodluck!!!
SOURCE: problem with code for apex ld3249
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
SOURCE: Apex LD3249 LCD tv.picture jumps
The tv Tuner board,that where the coalax broscast signal come in is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
SOURCE: I have tried to program a At&t U-verse remote
On uverse i got my apex to program by doing the search of codes. There is a code you can enter then hit a button to sequence through all codes by hitting power i believe. when tv turns off you know you have the right one. I am having the same issue on directv now since it does not have this option.
SOURCE: I lost my manual for
You can download a user's manual and others from;
http://safemanuals.com/user-guide-instructions-owner-manual/APEX%20DIGITAL/LD3249-_E
Click on the pdf icon on the right part of the page.
