WinZip 12.0 - Windows for PC  Logo
CarryMe Posted on Nov 03, 2012
Error code 1 installing winzip
When trying to install WinZip, it fails because it says I am not connected, but I am connected. I receive error code 1. Anyone know how to remedy this?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 11, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6453
Points
Error message wz30 appears when i try to open a zipped file
See this... http://kb.winzip.com/help/EN/WZ/help_chdir.htm?vid=nkln&ver=17.0.10381.0&mah=C2DCE02AC3A732BDF0537E4C1F324CD6872B2D6B&suname=Accipiter&sucode=D6H68-QJ26W-M0DQA-47UNE-VVM7C-06XK0
If you have purchased Winzip and need help, check here...
http://winzip.com/land_support.html
If all you need to do is unzip ".zip" files, you do not need to purchase WinZip. Windows XP, Windows 7, and Windows 8 all have a free extraction tool. You just right-click on a ".zip" file and click "Extract All". First, if you have already downloaded and installed the free WinZip, you can just Uninstall it.
Winzip cleverbridge
If all you need to do is unzip ".zip" files, you do not need to purchase WinZip. Windows XP, Windows 7, and Windows 8 all have a free extraction tool. You just right-click on a ".zip" file and click "Extract All". If you have downloaded and installed the free WinZip, you can just Uninstall it.
1helpful
Code activation
WinZip is a file compression utility that allows users to "zip" files into archives that have significantly smaller file sizes than the original files.
If you purchase WinZip directly from the WinZip website, a registration code is sent to you via email that allows the software to be used as soon as it is installed.
If you purchased the program from a third-party retailer, however, you must use an activation code to activate and register the software. Launch the WinZip program.
A screen will appear, reminding you to register your product and giving you the option to enter your name and registration information.
Enter your name where prompted.
Enter the activation code that came with your WinZip installation disc or in the activation information email you received when you purchased the product.
Click the "Register" button.
Enter all required information when the WinZip Activation Information screen appears.
This screen collects the information that WinZip Computing needs to properly register and activate your software.
Click the "OK" button to submit your information.
The WinZip software will transmit your information to WinZip Computing's activation server, registering your software with the company and receiving a registration number that it will use to activate your copy of WinZip.
Check the email address you entered when activating your copy of WinZip.
A copy of the registration information will be sent to you, including the registration number that was used to activate your software.
If you need to reinstall WinZip in the future, use the registration number instead of the activation code.
or
Its illegal for anyone to provide serial keys for programs that have retail values set on them there are freeware alternatives on the internet.
ZipGenius is a FREEWARE product
http://www.zipgenius.com/index.php?id=33
ZipGenius can handle more than .zip or .rar file
20 compressed archive types.
http://securezip-express-for-windows.soft32.com/
Free zip
http://www.all-freeware.com/details/154438/1-click-unzip-.html
http://en.softonic.com/s/winzip-8-freeware
Registration code
or use freeware
Free zip
2helpful
Winzip 16.5 activation code for pc
I'm sorry but this is not a warez site...We can't give out activation keys or access codes.
That being said, you should download and install a FREE program that is much better than winzip that can create and open all the same archives as winzip plus many more. It's called 7-zip, it's TOTALLY FREE, and you can download it here:
http://www.7-zip.org/
7helpful
Cannot install photoshop elements 6 in vista home edition
There is a problem with the auto-extractor.
Manually extract the files from the downloaded file using Winzip and extract to a new folder. Then run Setup.exe from that folder.
Also, make sure that your Temp folders have been cleared out.
The latest version of WinZip may be downloaded from http://www.winzip.com
Problems installing winzip companion20 for outlook
mostly your winzip been exired coz of trial ver, you cant able 2 install until copletly removed from the registry, try higher ver it works
Help
DOWNLOAD
Please follow the steps below to download the necessary drivers:
1. Go to the website http://support.epson.com
2. Under the ALL-IN-ONES heading select FLATBED and then your printer model.
3. Under the Drivers & Downloads section select WINDOWS. Download the most current version of the Printer Driver and Scanner TWAIN Drivers to your DESKTOP for your Windows operating system. You can also download the Status Monitor, if listed.
DOWNLOADED DRIVER INSTALLATION.
Scanner Installation
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off.
2) Locate and double click on the downloaded Twain driver installation file.
3) Click on OK at the first WinZip screen.
4) Click on UNZIP at the second WinZip screen.
5) Click on OK when WinZip is finished extracting files.
6) Follow the prompts to complete the installation.
Printer Installation
1) Locate and double click on the downloaded Printer Driver installation file on your DESKTOP.
2) Click on OK at the first WinZip screen.
3) Click on UNZIP at the second WinZip screen.
4) Click on OK when WinZip is finished extracting files.
5) At the PRINTER UTILITY SETUP screen, click on OK.
6) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer.
7) The computer will install the new hardware.
8) Click on OK when the driver installation is completed.
Status Monitor 3 Installation (optional)
1) DOUBLE-CLICK on the downloaded file.
2) Make sure the STATUS MONITOR is highlighted and then click on OK. The installer will now copy the necessary files to your computer.
3) When finished click OK and restart your computer.
1helpful
2answers
Epson CX3200 software
The links on Epson's page conatntly expire. Here are directions for you.
DOWNLOAD
Lost my installation disk
Top WinZip Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a WinZip Computer and Internet Expert? Answer questions, earn points and help others
