SOURCE: 2000 quest speedometer not working
Most common is the speedometer, for you speedometer issue. As for your radio display. If the radio works but has no display, then it's a radio problem not a fuse.
Thanks Jay!
SOURCE: replace control panel on 2004 nissan quest
there is a c-clip you need a small screwdriver to pull it out then gearshift knob will pull off
SOURCE: how long does a motor on 2000 nissan quest last for
Depends on how its maintained. You should get at least 200,000 or more miles if you take care of it.
SOURCE: 1997 nissan quest camshaft sensor where is it & how to replace it
The camshaft sensor is located inside the distributor and is part of it, in order to replace it you must replace the distributor,to replace remove the dist cap. mark the location of the rotor,by marking where its pointing to, then mark the dist housing, so now theres a mark on the rotor and housing to show where rotor points, next mark the location of dist going into housing, mark the shaft and the block,because it spins in block this way you can line back up.next remove hold down bolt and pull out,mark the new dist in exacat same spots as the old so you can install back the same,you may have to put it in and pull it out until your marks are lined up,this way the timing will be dead on, when done you can check timing. good luck
