On the keyboard i can not see anything when there is nolight in the room. i would think that there would be some kind of backlight on it...what can i do to turn the keyboardlight on
Check if the sensor of the ambient light in the room is dirty (bottom of TV). If so, the TV thinks its playing in a dark room and so sets the screen to dim.
If that doesn't improve things, turn a flashlight on the sensor to fool it into thinking its a brighter room.
What kind of Keyboard is that a gaming keyboard with all keys illuminated, if so to activate lighting, press the Backlight toggle key in the upper right corner of your Pro Gaming Keyboard.
if its a normal keyboard then your key board connectivity, check it firmly connected or any wire damages
try with liveUSB, you don't have to install anything to your computer and you can check all features and compatibilities. But on my laptop almost everything worked with backlight and fn keys.
To turn on the backlight on the keyboard follow the steps below.
The keyboard backlight LED can be accessed through either the Quickset Utility or Windows Mobility Center depending on the installed application.Once this is open click on the Keyboard Backlighting section. Make sure the keyboard light is turned on.
Thank You, Dell-Jesse L Dell Social Media and Communities
This can be called Optical picture control and it adjust to suit the room light.
Please read the text below"
Dynamic Backlight Control - One of the nice features of the Sharp AQUOS LC-32D6U is what Sharp calls OPC, a name they use for their dynamic backlight control. You might also see this feature referred to as a dynamic iris on other LCD HDTVs or disguised under some proprietary name, but fundamentally the principle is the same. Its primary function is to try and maintain a high Full On/Off contrast measures the ratio of the light output of an all white image (full on) and the light output of an all black (full off) image. 2) ANSI contrast is measured with a pattern of 16 alternating black and white rectangles. The average light output from the white rectangles is divided by the average light output of the black rectangles to determine the ANSI contrast ratio. When comparing the contrast ratio of video devices make sure you are comparing the same type of contrast. Full On/Off contrast will always be a larger number than ANSI contrast for the same video device.">contrast ratio under any lighting condition. So when room lights come on or off or the sun enters the room, with OPC enabled, the backlight in the LCD will dim or brighten depending on the amount of light in the room. This is managed by a light sensor located on the front of the unit. When OPC is enabled there can be a slight reduction in the dynamic range of the display as the display attempts to maintain contrast and color saturation as room light changes. We had a chance to compare this feature with another LCD HDTV that was of comparable size but without dynamic backlight control, and the Sharp AQUOS LC-32D6U with OPC enabled was the clear preference.
For latitude systems they have this ambient light sensor. it basically adjusts the brightness of the screen depening on room lighting. try to go to bios by hitting F2 on the dell logo. go to video and try to look for ambient light sensor. however, im not sure if your computer has that feature I have a second option for you though. based on the troubleshooting you've done, it seems that the video back lighting is affected by movement. it would be a good try to reseat the LCD cable. you can use this link to guide you in fixing the computer : http://support.dell.com/support/edocs/systems/latd505/sm/keyboard.htm
all you need to do is to take out the keyboard with 2 screw holding it in place. the LCD cable should then be accessible. it a thick cable that coming out of the Left hinge.
It sounds like the backlight has burned out. The faint light you are seeing is ambient light in your room being reflected through the LCD. Try it in a perfectly dark room and see if you can see anything on the screen.
The following page should give you a sense of what is involved in replacing a backlight:
http://home.comcast.net/~stonent/screenfix.htm
If you aren't comfortable taking things like this apart, I would recommend finding a local repair shop to replace the backlight.
My keyboard light doesn't work anymore either.
