Radio and cigarette lighter below it have no power
SOURCE: no power to the cigarette lighter. which fuse controls the power
The fuse for the cigarette lighter/accessory is located under the hood on the drivers side. There is a black box close to the firewall with many relays and I believe it is fuse 35?? Unscrew the cover and you will see a number of fuses and on the cover it will list the location of the fuses here.
SOURCE: Cigarette lighter not working properly in Pontiac...
This is a very common issue, either the ground at the back of the lighter socket is pulled off, or more likely the socket is defective, they are very easy to change, u can use a generic replacement from any parts store, the factory part will be at least 2X as much..
SOURCE: 2005 vibe radio and cig port stoped working
usually the radio and the cig lighter sharing the same fuse make sure it is the right fuse you looked at i check all the fuses
SOURCE: Pontiac G6 radio
probably not but the switch over is ez you probably need a harness..thats about it..
SOURCE: Which fuse runs the Cigarette lighter in a 1998
Fuse is call a
LTR Fuse
15 amp Color Blue.
Open drive side door you will see a fuse box cover.
Let me know if this help you...
