my phone will ring but no ringtone will play, i have every sound up and the silent mode is turned offmy phone will ring but no ringtone will play, i have every sound up and the silent mode is turned off
You can't post conmments that contain an email address.
Who is your carrier? the voice mail is set up via them call or web site. Your phone rings or not rings check ringer volume and ring tone and check if you always have a good signal.
Hi, the ringer of the phone that makes you hear when someone calls or when you want to listen to music is
faulty and needs to be replaced for you to be able to hear it ring when
someone calls you and when you play your song.
In ur mobile, there is a profiles folder.Just go into folder & select ur profile but before selecting it u have to edit it.
By editing,change the ringing type.
choose ring or max ring option & after that u wll definately get ur ring sound back.
Uh oh, I just saw this. Is it in the main board 101-108 exts, or one of the expansion boards?
Ringing is set 3 ways, by the switch on the side of the phone, by programming, by features. First, make sure the switch is in the ring position and have someone call you on the intercom. If it rings, have someone transfer an outside call to you. If it rings, try dialing 790 on the intercom to reset station features. If none of this works, It's time to look at ring programming. It's done from the system programming mode at the main phone or from a PC. It's program codes 408-410 or section 3.2 from the Maintenance console.
Did you checked your phone functions thoroughly that if it's deactivated from settings? Check that. Can your phone sound when you talk in loud speaker? or can you play the music or video? They sound?
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just activate divert if off (activating this one goes to ans phn if phn off activate divert if busy ( goes to ans phn if your on phone call) activate divert if out of reach (goes to ans phn if no signal) After doing these settings then your phone should ring when someone calls you. Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring. Let me know if you need further assistance ok let me know how you get on
