The ge 15312 is on the load side and the jumper wire was installed on the line side
GE 15312 sunsmart can be wired for single-pole or 3-way.
One 3-way switch is replaced. The other 3-way switch remains and is re-wired slightly so that timer programming can be reversed.
Wiring:
Copy following link to double-check wiring is correct:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html#3-way
Scroll down and look at each of the three 3-way illustration, Line side, load side, without neutral.
Here's how the timer works for 3-way:
When the red wire receives power, it reverses the timer programming of on-becomes-off or off-becomes-on.
So
the purpose of the remaining 3-way switch is to connect-or-disconnect
power to timer red wire >> this causes the 3-way effect.
Basically
the remaining 3-way switch is converted into a simple on-off switch by
using only one of the brass screws, and the dark screw.
So one of
the brass screws on the remaining 3-way switch has no wire connected to
it. It makes no difference which of the two brass screws is selected.
Add a comment as needed.
This timer has 1 year limited warranty through jasco, or just buy another one from Home Depot and return defect in new package.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
