Okay, thisu needs a bit more information. What server software are you running, what are the clients running and what type of networking are you using?
Have you tried instead of a proxy website an actual proxy server configured in internet explorer by going tools > internet options > connections > lan settings unchecking automatically detect and checking use a proxy server then enter the proxy servers information. Their are lists of proxy server ips available online just search "proxy list" in google
This error message indicates that the game server which you are attempting to connect to is unable to contact the Steam Authentication Servers.
Please observe the following process to determine whether the error is a result of a Steam outage, issues with the game server connecting to the Steam Authentication Servers, or an issue with your internect connection.
Try joining several different game servers - if you are able to connect to a different game server, there is an issue with the game server which reported the Server Verification Failed error
If you are not able to connect to any game servers, check the Steam Status page - if the Steam Players and Game Servers graph shows a very sharp decline in players, there may be a temporary Steam outage
If there does not appear to be an outage, check your connection to the Steam Authentication Servers through the Steam client:
From the main Steam window select File then Settings
Select the Internet tab
At the bottom of the window, confirm that Steam is reporting the Steam has successfully connected to the authentication servers. message
If Steam reports that you are not connected to the authentication servers, please exit and restart Steam and, if you are unable to connect to the Steam Authentication Servers upon logging back in and you have confirmed that there is not an outage, please see the Router and Router Firmware Issues topic to ensure the issue is not related to router firmware which is incompatible with Steam
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
Error #105 TCP connection to the server timed out.
IMPORTANT NOTE: If you
have received this error, you are not using the latest RealPlayer.
RealPlayer 8 Basic is a FREE, recommended update available for Windows
95/98/NT and recent Macintosh systems.
If your system meets the minimum system requirements, it is recommend that you update your player.
The attempt to connect to the TCP server took longer than allowed. This
problem may be caused by a high network load (i.e. too many people on the
internet) or the server maybe down.
If the load is too high, you may try later or you can increase how long
your computer waits by changing the Network timeout values under the
Connection tab in the RealPlayer Preferences. If the server is down, the
only solutions are to try a different server or contact the server
administrator for the site you are trying to access.
Your running a windows 98 server? Do you not mean Windows NT server? Windows 98 was not made to server as a server, there is no inherit file security permissions in place; just simple file/folder sharing.
If you need a simple file server, I would upgrade your 98 machine to windows 2000 or NT4.
Windows XP Professional works as a much more effective simple file server with much better security features.
specify your environment and OS etc
Bye
Can you see any of them in your network? Are you getting any errors?
Is the light of your network card green whit flashing amber light?
wired or wireless ?
