2005 Fiat Doblo 1.9 Logo
steve Posted on Oct 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to bleed the hydraulic clutch system - 2005 Fiat Doblo 1.9
Anonymous
Level 3:
  • Master 580 Answers
  • Posted on Oct 20, 2012
Anonymous
Master
Level 3:
Answers
580
Questions
0
Helped
127602
Points
1888
Your hydraulic clutch system is a wonderful smoothly operating method of engaging and disengaging the engine from the transmission. Most of the time. However, should you ever find the need to expel air from this hydraulic line...you may in for a long tedious experience.
I recently had to replace the master cylinder of my hydraulic clutch system. This was easily done as it comprised only one fluid line..and two bolts. Once the new master cylinder was mounted however, I found that air had gotten into the line..and adamantly refused to leave.
I undertook all of the common methods of removing this air but to no avail. I tried bleeding the system from the slave cylinder. I tried opening and closing the bleeder valve at the slave cylinder while someone pumped the clutch pedal for me. I tried using a vacuum pump to pull fluid and air out of the system. Each and every effort failed.
Air in a hydraulic line is a for certain way to insure that the hydraulic function will NOT occur. Air is compressible. A fluid is not. So when you place you foot on a brake pedal, or a clutch pedal and apply pressure, the non-compressing nature of that fluid, allows that fluid to behave as if there was an actual physical link in action. As an example..if there was a steel bar attached to your brake pedal..that would activate the brakes when you stepped on the brake pedal...that bar would be an actual, physical, material link..from pedal to brake shoe. A hydraulic line is very similar. When you step on the pedal..there is a force applied to the brakes..by the non compressing nature of the fluid..within that line...the force applied on that pedal, is instantly applied at the other end of that line...unless..there is air trapped within that line. The air will compress..stealing energy..and will not transmit the force applied.
I did a great deal of searching online trying to find a method of removing this air from my hydraulic clutch system and discovered some of what was causing the problem. The Bore of the piston inside the master cylinder is small...and the stroke or forward movement of that piston..is rather short. There just wasn't enough movement of fluid going on to force the air out of the system in a reasonable amount of time. But my search did bare fruit finally..I found a wonderful article on refilling a hydraulic clutch system..that eliminates air, takes only a very few minutes and is not at all expensive.
What you need is one of those oil cans that has a spout and a trigger that will squirt the oil for you. This trigger...should be of the type that requires your index and middle fingers to operate as opposed to a can that has a thumb trigger. You will also need a length of clear plastic tubing that will fit snugly over the end of the oil can's spout..and will also fit snugly over the end of the disconnected fluid line at the slave cylinder.
In practice..it's very easy. Remove the fluid line from the slave cylinder and allow the system to bleed out entirely. While that is going on, fill your oil can with fresh clean brake fluid. Attach the tubing to the spout..and once the system has bled out..attach the other end of the tubing to the fluid line. Start pumping...just regular timed pumps are needed. Not too fast. This fluid, coming in from the bottom..fills the system from the bottom..UP..and pushes any air right out through the master cylinder. Take a peek at the master cylinder every now and again. When you see it beginning to fill with fluid...go ahead and fill it completely with brake fluid. Slip under the vehicle, re-connect the fluid line, pop open the bleeder on the slave cylinder..watch for fluid to come out...tighten the bleeder close again..and you are finished.
1helpful
2answers
Does Toyota hilux R150 gear box have a clutch adjustment ?ie master cylinder adjustment ?
If it is adjustable it will have a threaded push rod at the slave cyl ,bleed the hydraulic system first adult the clutch then bleed again .
Is it true that u need to bleed a clutch on a mits mirage 2001 car?
If you have replaced the clutch master cylinder or slave cylinder,then you do need to bleed,here's a link on how to bleed your clutch. Repair Guides Clutch Hydraulic System AutoZone com
2answers
How do you bleed a hydraulic clutch on a 1977 corvette
you bleed like you would the brake system. there is a bleeder screw on the slave cylinder that you bleed the system.
I have an 84 Honda shadow vt700. The clutch was working but would slip when hot it would get to where I could release clutch with bike in 1st gear and nothing would happen! It would just continue to idle!...
Bleeding the hydraulics will not improve the friction drive of the clutch in any way,your clutch drive plate is worn out and needs replacing. To bleed the hydraulic line ,make sure that the master cylinder is fully topped up,pump clutch lever several times then tie ,using a zip tie the clutch lever all the way to the handle bar,gently open the bleed screw and await fluid to start dripping from the bleed screw, this may take an hour or two but it will eventually bleed itself,once 25% of the fluid has discharged from the the master cylinder tighten up the bleed screw and this is the easiest DIY way of bleeding a hydraulic system, without a pressure bleeder.
How do you bleed the hydraulic clutch on 1984 944
924 has cable operated clutch. When the cable on mine broke pedal went straight to the floor, hydraulic usually much slower to get to floor. Cable is an easy replacement. bleeding hydraulic usually done from nipple on slave cylinder (near release arm on clutch housing.
2helpful
3answers
How do you bleed the clutch hydraulic system on a 2008 Mustang?
you bleed a hydraulic clutch the same way you bleed a brake system and it uses brake fluid as well.you keep bleeding until there is no more air in the clutch system.there should be a bleeder screw on the clutch slave cylinder that is were you bleed the clutch from.
Clutch slave cylinder how to bleed
HYDRAULIC SYSTEM BLEEDING Do not use fluid which has been bled from a system to fill the reservoir as it may be aerated, have too much moisture content or possibly be contaminated. Clean the dirt and grease from the cap to ensure that no foreign substances enter the system. It is also important to maintain the fluid level in the clutch reservoir to the top step with hydraulic clutch fluid Hydraulic Clutch Fluid GM P/N 12345347 or equivalent.
  1. Attach a hose to the bleeder screw on the clutch actuator assembly and submerge the other end of the hose in a container of hydraulic clutch fluid.
  2. Depress the clutch pedal slowly and hold.
  3. Loosen the bleeder screw to purge air.
  4. Tighten the bleeder screw to 18 inch lbs. (2 Nm).
  5. Let up on the clutch pedal.
  6. Repeat Steps 2 through 5 until all air is purged from the system.
  7. Fill the reservoir to the top step with hydraulic clutch fluid.
  8. Repeat this bleeding procedure if there is a grinding noise during the clutch spin down procedure.
3helpful
My clutch is not angaging need to see how can i bleed
Hydraulic Clutch System BLEEDING The clutch system can be bled using a pressure bleeder. Follow the instructions that come with the pressure bleeder for the proper pressure bleeding procedure. The maximum line pressure while pressure bleeding must not exceed 36 psi (248 kPa). NOTE: To bleed a clutch manually requires the assistance of a second person, a section of hose that is compatible with brake fluid (preferably clear) and fits the slave cylinder bleed screw snugly and a container to catch the fluid that is bled through the system. As brake hydraulic fluid easily absorbs moisture, always use fresh fluid when bleeding a hydraulic system.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. To bleed the system perform the following:
    1. Top off the hydraulic fluid reservoir using a fluid that meets the standards of the vehicle's hydraulic system.
    2. Open the clutch slave cylinder bleed screw and press the clutch pedal to the floor and hold the pedal down.
    3. Close the clutch slave cylinder bleed screw.
    4. Release the clutch pedal.
    5. Check the hydraulic fluid level and top off as necessary.
  3. Repeat the above steps until the discharged fluid is clean and no air bubbles appear during the bleeding process.
2helpful
Clutch won't engage--cannot shift
hydraulic clutch needs servicing or needs bleeding like a brake system wont work with air in the lines neither will hydraulic clutch's. you shouldnt have to change the clutch just service the slave cylinder ,that should give you back some pedal to use..you might want a mechanic to bleed it or have it replaced.
Top Fiat Experts
ZJ Limited
ZJ Limited
Any Car Diagnostic...
Sean Wright
Sean Wright
Are you a Fiat Expert? Answer questions, earn points and help others
