Most weed eater products are two cycle. if you have to mix oil with the gas they are two cycle. If there is no place to add the oil like a four cycle then its two cycle. Do not run a two cycle engine without adding oil to the gas or you will burn it out fast
Not an easy job to get to on this Weedeater made blower; have plenty of work space and a very good memory. It requires removing blower end which you will end up disassembling the whole casing.
When re-assembling don't over torque the fan mounting nut as it will cause the flywheel to bind.
Oil leaking.? The only oil that would be in the machine would be the 2 stroke mixed in the fuel.. I dont understand where 'oil' would be leaking from. (more info please)
Also your question refers to an 'older homelite weedeater' yet its titled 'Problem with Stihl BR400 Backpack Leaf Blower' Which one is it.?
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
