SOURCE: Broken pioneer premier avic f90bt
hope this helps...http://avic411.com/forum/viewtopic.php?f=33&t=25424&p=173322&hilit=+black+screen#p173322
SOURCE: Pioneer AVIC-N3 Problem
Sounds like you are having a problem with the ribbon cable from the screen to the board .you can find the cable at many places even in Ebay .Usually the price is around $60.00.
SOURCE: i have a pioneer avic-s1
try and reset it there's a reset button on the bottom somewhere use a paperclip to see if you can reset the device then try it. if it doesn't work then update your software again to the sd card and it should work
SOURCE: Pioneer Avic-F700BT worked perfectly fine for 7 months but....
Hello!
My pos just did this today after I got in a hot car (had windows up for security).
Symptoms:
Briefly displayed the PIONEER default splash screen, LED lighting was the default ... light/bright pink (to match pioneer?).
Then screen goes black, then backlight gets fully dimmed and LED dims to darks white (R,01G,01B01)
Wouldn't really respond to anything... but plays CD in background.
I had a brainstorm while sitting in my car at ACC (ignition) and reading the lame online TS guide.
I turned my car to ON and put the gear shift in REVERSE.
The screen flashed to the password, and flashed black again....
Some how the system stablelized after some time and I resurrected it*.
* After tinkering I found ALL settings except the NAV data/settings had been lost.
In addition I believe corruption has occured in the memory holding the voice data. TTS... that phone thing voice command wont display when i press down on the Multi-nav? dial. Also system crashes when I try to access language settings. Sometimes a Windows CE error message bled thru reporting a fatal application error. Illegal operation request...
Hope this helps. I think my POS is going back to cartoys before my 30days is up.
Pity
SOURCE: pioneer avic 700bt
The Avic F700BT does not have a DVD player, it only has a CD player. If you want DVD capabilities you need the Avic F900BT.
