My 1991 Chevy silverado door is stuck open I have shaved door handles and the door will not close it hits the pin on the body that the latch on the door goes around when I pull the interior handle its loose and wont open the latch any one know what the problem is
SOURCE: 1998 chevy truck 1500 door latches
The handle mechanism wears over time. I went on eBay, bought a color matching handle for under $20 and replaced it myself. You have to be careful when removing the plastic panel bezel that surrounds the handle, drill out two rivets and your door will open like new!
SOURCE: trying to adjust outer door handle rod. how to
Once you remove the door panel, you will see the linkage and rods. The rods are connected with these little "swing away" plastic fasteners. Basically, these fasteners have a hole on one end and a sort of channel which snaps onto the connecting rods. To remove them you just unsnap them from the connecting rods. I'm enclosing 2 pictures of typical awing away connectors. In the pictures, it's the square end which needs to be unsnapped. Hope this helps, if you need any further clarification, just post a comment.
SOURCE: the tailgate latch on our 2006 Chevy truck is in the open positio
there are little metal rods that connect to the handle of the tailgate, just like the rods that connect your door handles to the door hinges and lock mechanism. just pop off the plastic cover over the tailgate handle and check and see if the rods are still connected to the handle.
SOURCE: cant open door from inside,i
This is common in the Chevy's... The inner rods/clips etc get stretched from use and the handles even break inside the door and you can't tell until you remove the door panel. I know of people who have replaced all four as routine maintenance! good luck
You will need to remove the door panel and inspect the latch rods, one may be off the latch.
hinges are bent
