Power Acoustik A3000DB Car Audio Amplifier Logo
Posted on Dec 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power acoustic ov1-30000 3000w gothic series
This amp turns on fine but no sound comes out of it i dont see anything wrong with the inputs or the outputs by the way the sub is a kicker L7 12. I also have a 1 farad capacitor and 4awg cable.
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Dec 29, 2008
Anonymous
Expert
Level 2:
Answers
62
Questions
0
Helped
20325
Points
127
IT SEEMS TO ME THAT THE RADIO MAY HAVE A OUTPUT FOR THE SUBS OR REAR RCA CHECK RADIO MENU AND SEE IF THIS IS ON OR OFF
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
1helpful
Acoustic reaserch subwoofer dont have any sound
If this is a powered sub then it's most likely the internal amp inside it that has failed. It's more than likely the part that works the hardest on the board. IE the main amp semicoductor.
I have two amps my power acoustic ov2-1800 stays in protect mode when i turn my car on, and my other amp is a JL Audio and it goes in and out of procect mode randomly??? Any insight???
You have a short. Check all power connections to both amps, all the way back to the battery. Then check to make sure speakers are connected properly
2helpful
I have a power acoustic gothic series 1600 watt amp, it was playing fine last night and just went off, protect light on. Today i tried it, there is a very small amount of sound thru the speakers but thats...
There are really only two possibilities here. If you have the gain turned up too high then your amp will get over worked and will go into protect mode. It is a safety feature. You should never really have the gain at much over 50% up. If you have to consistently run it higher than that you are overworking your amp and it will either shut down to protect itself or you will fry it.
1helpful
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
My amp is flashing in and out of protect
you must likey just fryed the wires, try putting in bigger fuses, and unhooking everything and re hooking it up
Red light
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
