SOURCE: All fuel lines are off and replaced fuel primer
You will need to disassemble the carburetor and spray
with carb.cleaner. Make sure the small screen in the carb. is free of
debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
SOURCE: gas line with filter broke inside tank how to
get new line cut end at an angle , lube with oil and twist it in, snag the line and pull it out the filler hole and insert filter on the end, connect and enjoy.
SOURCE: how to test a poulan pro 31cc ppb 250e gas string
The proper way to test it is with an ohm meter by doing a continuity test. If your switch isn't working on the machine, there is the possibility that the wire from it that connects to the coil module is loose or is off. I would check for that first and then do the continuity test if needed. The coil is under the front cover of the machine and will require disassembly to access where the black switch wire spade terminal is.
SOURCE: changed filter and fuel lines, poulan 31cc 250E. starts fine but dies when accelarated
My chainsaw was doing this.The carburetors on these small engines have a fuel inlet screen that clogs with tiny bits of debris.Remove the carb,and take the portion off that has the fuel line attached to it(if you're careful,you can reassemble it without needing a new gasket).The screen is about 5/16" in diameter.Spray some carb cleaner in there to clean the screen out.(this is mt best guess,because it sounds like a fuel starvation problem)
Poulan Pro Weed Eater. 31cc PPB200E, Crancks good, runs as Long keep chock on , New Carberater, New fuel lines, New fuel filter
