1992 Lincoln Town Car Logo
Posted on Dec 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dim headlight on 92 town car
92 Lincoln town car, the left headlamp went dim. i had high/low but dim. when i pulled the lamp the glass was burnt and one filament was broken. install new lamp same dim response. i get 12 volts on both sides but when i disconnect the right hand lamp the left goes out. anyone got a clue?
thanks,
ed
Anonymous
Level 3:
  • Master 659 Answers
  • Posted on Dec 29, 2008
Anonymous
Master
Level 3:
Answers
659
Questions
Helped
338753
Points
2279
Make sure the terminals are clean at the headlamps. check the black wire to ground for open circuit. an open ground will cause a dim headlamp if there is no way to test wire jump the black wire to ground and see if lamp brightens
2answers
My head lights went out but my parking light are still on what could be the problem
I would check the fuses first. Headlights are typically on a separate fuse then the parking lights. If the fuse is fine check and see if the Bulb is burnt out but it is rare for both lights to go out at the same time.
My pontiac 2006 g6 headlights are not working proper drivers side only works in high beam and I only get a faint low beam on passenger side
How did jump starting the vehicle burn headlamp wire ? Check the left low beam fuse # 7 10 amp - located in the underhood fuse / relay box. Does the high beam work on the right side ? The light that is dimly lit has a ground issue or not enough voltage ,testing that circuit using voltage drop testing would be the way to find the problem . Do you know what a wiring diagrams is ? an how to read one ? How to use a DVOM - digital volt ohm meter to test electrical circuit's ? Watch these two guy's video on voltage drop testing.
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year ,make , model an engine . Under system click on lighting , then under subsystem click on headlamps . Click the search button then the blue link . Learning how is the first step in automotive electrical diagnostic's .
Electric Testing Techniques You Need to Know
Driver side low and high beam on but dim. Passenger side low beam normal but high beam on and dim
I would check for the groundwire continuity
Driver side - dim low beams and no hi beam - Subaru Outback ...
www.subaruoutback.org > ... > General > Electrical & Electronics
Oct 11, 2014 - Hi everyone, My drivers side headlights are dim on low, (car has separate bulbs ... When the headlight switch is turned ON, but for low beams, ...
Driver-side Low beam Not Working (electrical issue not bulb ...
www.hummer4x4offroad.com/.../showthread.php?...Driver-side-Low-be...
Mar 12, 2015 - 10 posts - ‎4 authors
The high beam continues to work on both sides...I pulled the Driverside headlamp fuse and then both left and right beams lit up but very dim.
High beams ok, but not low beam - one side only - TDIClub Forums
forums.tdiclub.com > ... > VW MKIV-A4 TDIs (VE and PD)
Jan 23, 2014 - My driver's side lights are working fine - high and low beams. ... But it definitely looks like the big lamp on the driver's side gets brighter when ..... Drivers side headlight is very dim on low beam and goes out when on high beam ...
Dim driver's side headlight (low & high beam) - GrandAmGT.com Forum
www.grandamgt.com > ... > Technical Q&A
Dec 11, 2002 - 6 posts - ‎4 authors
Why don't lights work?
Both the headlight switch and the BCM provide a ground, or control circuit, to the headlight relay coil circuit for manual or automatic headlamp operation. When you place the headlamp switch in the OFF position, and the ambient light sensor indicates low light conditions, the BCM energizes the headlamp relay for low beam operation. You may switch the headlights to high beam by pulling the dimmer switch handle toward you until the dimmer switch is activated. When the dimmer switch is placed in the HIGH position, the indicator lamp input to the BCM is pulled low. The BCM then sends a class 2 message to the instrument cluster in order to illuminate the high beam indicator lamp.
Low and High Beams Headlamps Inoperative ?
Replace the headlamp switch. Refer to Headlamp Switch Replacement .
Did you check the headlamp relay ? Location ,left instrument panel
Did
Why wont the headights or running lights work on my 2002 Buick LaSabre?
There are several reasons why your headlamps an running lights don't work , the headlamp switch is a good one ,plus relays an the DIM - dash integrated module an associated wiring ! Here is how the headlamps work , right out of Buick factory service info !
The dash integration module (DIM) provides battery positive voltage to the signal circuits of the headlamp switch. The signal circuits include the headlamp switch headlamps on signal, the flash to pass switch signal and the high beam input. With the headlamp switch in the ON position, a ground path is available for the headlamp switch headlamps on signal circuit of the DIM through the headlamp switch. The DIM provides ground to either the headlamps high beam relay control circuit or the headlamps low beam relay control circuit of the low beam circuit. The position of the headlamp dimmer switch determines which relay control circuit has ground. The DIM supplies battery positive voltage to the relay control circuits, if the headlamps are necessary. The fuse block - underhood supplies battery positive voltage to both relay switch circuits. When the low beam relay control circuit is energized, current flow is to both low beam fuses and to the low beam headlamps. The headlamps have ground at G103 and at G401. When the headlamp high beam relay control circuit is energized, current flow is to both high beam fuses and to the high beam headlamps. The high beam circuit is divided into a left and right side circuit. The current flow of the left high beam is from the fuse to the left high beam lamp. From the lamp, the current flows to the normally-closed contact of the DRL relay to G103. The current flow of the right high beam is from the fuse to the right high beam lamp. From the lamp, the current flow is to ground at G401. When the headlamp dimmer switch lever is pulled toward the driver, the flash-to-pass switch closes. This grounds the DIM flash to pass switch signal circuit. In response to this input, the DIM energizes the HDLP HI BM relay. Both high beams remain on until the driver releases the switch handle. If the low beam headlamps were on during a flash to pass operation, the low beams remain on. The headlights may be switched to high beam with the opposite movement of the headlamp dimmer switch lever.
By running lights , do you mean park lamps or day time running lamps ?
Park, Tail, License and Marker Lamps
The park lamps, including the license lamps, are turned on when the headlamp switch is placed in the PARK or ON position or anytime the headlights are requested. The fuse block - rear supplies battery positive voltage to the switch contacts of the Park LP relay. When the headlamp switch is in PARK or in ON, the park lamp switch on signal circuit of the DIM has a ground path. The DIM provides battery positive voltage to the control circuit of the Park LP relay. When the park lamps and/or the tail lamps are ON, the DIM energizes the park lamp relay control circuit. This closes the switch contacts. Current flows from the Park LP relay to the LH PARK LP and the RH PARK LP fuses. From the fuse, the current flows to the park lamps. The left park lamps are grounded at G103, G401 and G402. The right park lamps and the right tail lamps are grounded at G103 and G401. The DIMR fuse supplies battery positive voltage to the license lamps and to the DIM instrument panel lamp fuse supply voltage - 1 circuit, for interior lamps dimming. The license lamps are grounded at G401.
The best advice I can give is that you take this to a ASE certified professional repair facility unless your a qualified automotive electric repair person !
Diagnostic Starting Point - Lighting Systems
Begin the system diagnosis with the Diagnostic System Check - Lighting Systems . The Diagnostic System Check will provide the following information:
The identification of the control modules which command the system
The ability of the control modules to communicate through the serial data circuit
The identification of any stored diagnostic trouble codes (DTCs) and their status
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
The
Oldsmobile intrigue problems
The switch is bad >
Each headlamp is individually fused so that battery voltage is applied to the individual lamps at all times through circuit 1640 for the LH headlamps and through circuit 1740 for the RH headlamps. When the headlamp switch is in HEAD, the ground is applied directly to headlamp switch through circuit 1750. When the headlamp switch is placed in LOW, ground is applied to the low beam headlamps through circuit 1201. When the headlamp switch is placed in HIGH, ground is applied to the high beam lamps and to the high beam indicator through circuit 1200. The high beam indicator is fused so that battery voltage is applied at all times through circuit 640.
The box you hear the click in is the daytime running lights control module .
Do you know how to do electrical testing using a DVOM- digital volt ohm meter or a test light ?
Step
Action
Value(s)
Yes
No
Was the headlight system check performed?
YES - Go to Step 2
NO - Go to Headlight System Check
Does flash to pass function normally in the headlight system check?
YES - Go to Step 3
NO - Go to Step 7
Does the autolamps low and high beam operate normally?
YES - Go to Step 4
NO - Go to Step 6
Turn the headlamp switch to the Head position and the headlamp dimmer switch to Low position.
Using a test lamp, backprobe between connector C201 terminal W and ground.
Is the test lamp on?
YES - Go to Step 5
NO - Go to Step 6
5
Repair poor connection or open in circuit 1750 between connector C201 terminal W and S283.
Is the repair complete?
6
Replace the headlamp switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle for service procedure.
7
Repair poor connection or open in circuit 1750 between S283 and ground.
1helpful
My 2002 impala headlights don't work at night or in dark places like a tunnel or under a bridge, they only work in the day time. I have day time runner lights and they automatically turn on when I start my...
You can't turn them on manually with the switch . You have the switch set on auto ?
Headlamps
You can use the headlamps in two different ways.
• Place the headlamp switch in the ON position for normal operation.
• Place the headlamp switch in the OFF position for automatic lamp control (ALC). During ALC the high beam headlamps are On at reduced intensity for daytime running lamp (DRL) operation in daylight conditions, or low beam headlamps On in low light conditions.
The DRL/EXT LTS fuse and the EXT lamps fuse in the underhood junction block supply battery positive voltage at all times to both of low beam lamps and to the right high beam lamp. The low beam circuit continues to the high/low beam switch, then, depending on the position of the dimmer switch, connects to the normally-open headlamp relay switch contacts. Placing the headlamp switch in the HEAD position provides a ground path for the headlamp switch input of the Body Control Module (BCM). After receiving this input, the BCM energizes the headlamp relay. When the headlamp relay is energized, the low beam circuit is connected to ground G201. The high beam circuit is divided into a left and a right side circuit.
The DRL/EXT LTS fuse in the underhood ignition block supplies battery positive voltage to both the coil and to the normally-closed contact of the DRL relay switch circuit. During high beam operation, the left side current flow is through the closed contacts of the DRL relay, and to the left high beam lamp.
The EXT Lamps fuse in the top of the engine fuse block supplies battery positive voltage to the right high beam lamp. Both high beam circuits are then connected together, and continue to the dimmer switch. When the driver closes the high beam contacts of the dimmer switch, the circuit is grounded at G201.
If the headlamp switch is left in the head position, the inadvertent power control feature will turn off the headlights 10 minutes after you turn the ignition switch to the OFF position. If you place the headlamp switch in the head position after the ignition switch has been turned OFF, or if the ignition switch is in the ACCY position, the headlights will remain ON until you turn them OFF or until the battery runs dead.
2002 Dodge Caravan headlamps: one works on dim the other works on high beam but not together. Also only one daytime running lamp.
Your van has dual diligent headlamp bulbs, that means each headlight has one bulb that serves as high beam and low beam. What has most likely happened is on one side the low beam filament has burnt out, and on the other side the high beam filiment has burnt out. The daytime running lights are just the high beam filament running on reduced power, so if the high beam doesn't work on one side, that same side will have no daytime running light. Replace both headlamp bulbs with matching, good quality bulbs.
17helpful
2answers
How do I replace the headlight bulb on a 2005 Town Car?
1. Remove the three pin-type retainers, two screws and the radiator defector.
2. Remove the 4 bolts securing the headlamp assembly and remove headlamp assembly.
- Disconnect electrical connector
3. Remove the 3 hex-head bolts and 2 torx-head screws and remove headlamp protective cover.
4. *****Standard low-beam bulb*****
Disconnect the connector from the bulb and remove the low beam bulb.
5. *****HID low beam bulb*****
Release the spring tabs and remove the HID low beam bulb
6. *****High beam bulb*****
Disconnect the electrical connector and remove the high beam bulb.
Reverse order to install
2helpful
Passenger headlight don't work 2003 lincoln navagator
high beam or low beam? or both of them on one side.
  • One low beam headlamp is inoperative
  • Central junction box (CJB) fuse 23 (10A) (RH headlamp).
  • CJB fuse 25 (10A) (LH headlamp).
  • Circuitry.
  • CJB.
  • Go To Pinpoint Test C .
  • One high beam headlamp is inoperative
  • Circuitry.
  • Headlamp assembly.
  • Go To Pinpoint Test D .
  • The high and low beam headlamp is inoperative on one side
  • Circuitry.
  • REPAIR ground circuit 57 (BK).
  • Headlamp switch
  • Multifunction switch
  • Vehicle Security Module
  • Central junction box (CJB) fuse(s):
    • 17 (15A)
    • 23 (10A)
    • 25 (10A)
    • 35 (20A)
    • 40 (20A)
  • Circuitry
  • Headlamp bulbs
  • Daytime running lamp (DRL) relay
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
