Are you wiring for 3-way or single pole?
In other words, are you using 1 switch (single-pole) or 2 switches (3-way)
http://waterheatertimer.org/pdf/Pass-and-seymour-3-way-3-speed-fan-control.pdf
Before installing device, separate all wires in box and turn power on and then test each wire to bare ground wire >> tester will light up on Hot power source.
Black wire on device is connected to Hot power source.
Red wire on same side of device as black wire is capped off in single pole application.
Red wire on other side of device from black wire goes to the fan motor.
Green wire is ground.
Set fan on highest speed before connecting red wire to fan, and then do not adjust fan speed using pull chain.
I am unsure what volt-amp-testing will show for power output on either red wire, but certainly it will vary as the switch is adjusted to each speed.
Call 800-223-4185 for Legrand tech support.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I connected the black wire to the power source and the red to the fan power. I'm using the switch in a single pole setup so the second red wire is capped. When I turn the switch off, turn the power back on at the panel, there is power running to both of the red wires. I don't know how much power, but I was thinking there shouldn't be any power when the switch is turned off. I tried turning the switch off and on and nothing changes. The fan speed I just left in the lowest setting
Ok, just talked to Legrand tech support and I have an answer. The switch has a power indicator light. Apparently this is a low voltage light, but the power runs through the entire circuit and back to the switch. They said a small amount of power runs to the fan and back completely the circuit. That's why I was getting a reading at the fan location, even when the switch was in the off position. The power should be low voltage and not damage the fan.
Thanks for update. The answer from Legrand makes sense since the switch controls fan speed by lowering or raising the power on red line.http://waterheatertimer.org/images/3-spe...
SOURCE: Voltage on dimmer switch constant
That red wire is hot, it's used in what is called a 'switch loop'. That's where the electrician will bring the hot for the circuit to the light first, then run down to the switch and back with the switched hot for the light. Turn the breaker off!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: pass and seymour ws 3000 Hooking up to basement I
You're right, green goes to ground.
Black wire connects to Hot wire from breaker box
Red goes to Load (fan, light, motor)
Ok which wire on the switch goes to the Load?
And which goes to Hot from breaker box?
You can test or you can simply hook up the device. If it doesn't work, swap the two wires.
It just won't work until the 2 wires are correct.
SOURCE: I'm want to install a
More information is needed.
Unknown what wiring device was there before, and which wires were connected to which screw terminals.
Wire color is not as important as knowing what wire is for.
If both white wires were connected together before, then they need to be put back same way.
Separate wires. Turn on power. Test each wire to bare ground. Tester lights up on Hot wire. The Hot wire is usually black.
In back of box are white wires twisted together and covered with wire nuts. These are the neutrals.
Test black hot wire to neutrals and tester will light up. If box does not have neutrals, then device cannot be installed to code.
Open following link for illustration of wiring:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
