Replace the rechargeable battery
Refer to
rechargeable battery ?
SOURCE: remington shaver ms 280 screen has a hole
How do you replace (change) the screens on a Reminton MS-280?
"Paz"
Roger
SOURCE: I own a Braun Electric Shaver Model 6525 Flex
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
SOURCE: My Braun 5564 electric/rechargeable razor will no
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
SOURCE: Replacing the battery
that manual does not have the battery removal instructions. I am trying to do the same thing and have only disassembled part of it and cant figure out how to get the main case off. I took off every visable screw and removed rubber pieces only to find out there werent any screws underneath.
SOURCE: How do I open the Remington 9190 Electric Shaver
Remove the Two ( 2 ) Phillips Head screws on the Back side of the
R 9190 shaver near the Electrical Plug .
Pry off the Gray Rubber cover that those two ( 2 ) now removed screws went thru.
Now remove the Two ( 2 ) exposed screws up near the " Trimmer Switch "
Note: If you Popped off the " Trimmer Switch " during your efforts - DON'T WORRY . It will simply pop back in place when you are finished with your repairs.
