Daughter entered the wrong codes, the phone asks for a pin, the pin passed but the phone asks for PUK
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater
Same Your No Problem will Solved
SOURCE: hi - bought a nokia
Hi, first of all, you did a grave mistake by entering the wrong pin which resulted in it asking for your PUK (Personal Unblocking code), and 12345678 is not and never your PUK
All sim card have a unique PUK for security reason and they come along with the sim pack when bought new, but should in case you have misplace your sim pack, you can contact your service provider to ask for you PUK which will be given to you free of charge but they might likely ask you for the proof of ownership and your imei number which can be generated by dialing *#06# on your phone...
Take care
SOURCE: From a previous questioner: "After being asked to
Hi.
Test using a different compatible SIM card, since the PUK code lock belongs to the SIM and not to the phone, the new SIM will be initially unlocked, or will ask its own PIN code.
If the new SIM gets locked by itself, then the problem is the phone. If the problem does not occur with the new SIM, the original SIM card was defective.
If the problem happens again with a brand new SIM, then you will need first to reset the phone to factory settings. If still no luck, reinstall the phone firmware. See link below on firmware update. If you go for the upgrade, ensure that you download right firmware. Read instructions and perform procedure as explained. If done in the wrong way the firmware update may damage the phone.
Secret codes to reset and get info:
Note format and factory reset will delete the files stored in the phone.
Nokia Europe - Device software update - Support
Test a different SIM card first.
SOURCE: my daughters phone says "pin blocked , enter PUK
Get the unlock code here http://www.wickedunlock.com/unlock-your-phone/rs11wp2/ and for puk code contact the service provider..
SOURCE: I have a samsung cell phone model SGH-T105G (TF)
You need to ask for the PUK code from the network operator. They will give it for free. Also, if you still have the envelope from the sim card, the PUK code is written on it.
Warning: if you enter 10 times the wrong PUK, the sim card will be permanently disabled.
