Hello friend, thank you for your post!
From my understanding you have some questions regarding the operation of your Frigidaire microwave. The fan will turn on when the temperature sensor recognizes the temperature is too hot. There should be suction from the bottom. If you are experiencing issues with your new microwave I would recommend contacting your manufacturer for proper warranty coverage. I hope this information is helpful to you. -Matt
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
That's a great question, friend!
I see you question is labeled under model FGES3065KB. In order to remove the drawer on that specific Frigidaire range you would need to follow these steps:
1. Open the drawer to full position.
2. Locate the latches on both sides of the drawer.
3. Pull up on the left glide latch and push down on the right glide latch.
4. Pull the drawer away from your range.
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
