Access glow in the dark release on drivers side of boot lid inside trunk via ski pass through door behind center armrest of rear seat. As I understand it if batteries are dead emergency relase does not work. There may be alternate means of providing power to use this switch by attaching a 12v charging wire to cigarette kighter.
This is all the Bentley shows:
Location: Driver's side door trim in storage compartment.
Removing:
- Remove driver's side door trim:
Repair
Manual, Body Interior, Repair Group 70 - Unplug connectors.
Carefully disengage catches -arrows-.
Press switch for interior monitoring and towing protection -1- or trunk release
switch -2- out of trim toward rear.
Installing
Installation is carried out in the reverse ordBentley Boot lid manual release - doorlockswitch3.gifg src="/uploads/images/doorlockswitch3.gif" alt="doorlockswitch3.gif" class="h_mi" />
Remove trunk lid lock.
Repair Manual, Body Exterior, Repair Group 55
- Use a flat screwdriver to pry plastic tab -3- off retaining
pins -1-.
- Bend plastic tab fully to rear.
- Pull contact switch -2- first sideways and then up and out of
trunk lid lock.
Installing
Install in reverse order, paying attention
to the following:
Note:
Make sure that washers are correctly
seated between plastic tab and trunk lid lock.
SOURCE: Chevy Impala 2007 trunk lid release
Fold down rear seat and climb in the trunk....there is a manual release at the center of the trunk lid. (mandated by the government to kids don't get trapped in the trunk).
SOURCE: I have a 2000 Bentley and I can't remove the rear set to pull the manual trunk release
If I am not mistaken, you have to remove the head rests, remove the bottom bench, fold down the armrest and remove the bolts behind it (Note: At the bottom, the bolts for the seat are held in by a clip... You just take a flathead screwdriver and pry it forward and it will then release. Make sure you dont let the seat-belts retract; it be difficult to get it back.) Typically, it takes about 2 hours to remove the seats. You will also need a metric set of Allen and Socket Wrenches to remove the bolts.
go here >http://forums.audiworld.com/showthread.p...
