I bought these and there were was no instrutction manual inclueded. Is it possible to have a manual sent to me? I believe the best description for them is as follows: This is a set of indoor / outdoor wireless speakers from Sharper Image. Comes with 900 MHZ Transmitter. Speaker roughly 10 inches tall. Transmitter connects to any stereo or MP3 player and sends audio through walls and floors to the wall mountable speakes. Weather resistant housing permits placement within 150 feet of transmitter Thanks. Tina
SOURCE: I have a sharper Image mp3 player cant figure out
With music (or whatever)playing hold down V button (left hand side of control circle)til volume adjustment screen comes up-a blinking speaker. Press PRE or NEXT button (top and bottom arrows) to adjust volume.
SOURCE: need a user manual for Sharper Image MP3 player
This is the direct link to the pdf of the manual http://www.mscustomercare.com/forms/MP3_Camera_IM.pdf
:D
SOURCE: Connent Bose speakers to Sharper Image SA250 System
Probably. HTIB's are all-in-one for a reason. They typically are not recommended (or explicitly recommended against) mixing and matching with other products or damage can result. Glaring (but not mandatory) evidence of that would be non-standard connections that don't use bare wire ends to connect the speakers to the amps.
I can't find documentation on the SA250. How are you connecting the 501's to it?
SOURCE: sharper image wireless speakers, model CT 413,
My speakers were working fine on my TV, I disconntect them, then when I re-connected the transmitter no signal is received and nothing is heard via the spearkers either.
SOURCE: my sharper image eca115 does
Are you connecting with mini cable? make sure you have right cables... Apple uses a 3 ring mini end where most mp3 players use a 2 ring connector
