Hit water. replaced sparkplugs,ignition module,checked fuel pump and filter.checked compreson. all good
SOURCE: Fuel Injector Wont Spray
check wires at throttle body. can use a 12 volt test light to check for current. if you have spark it is not the ign module. set meter for 12-20volts. should have 2 fuse boxes on this model, one behind right side of dash at floorboard
SOURCE: car wont start
I noticed you replace the crankshaft sensor, but not the CAMshaft sensor.
The Ignition module takes the input of both sensors to tell the coil when to energize.
This sensor should come up as an error code when you attach a obd reader.
Even if your light is not on - there may be a code. If it is not your vehicle originally, some people pull the bulb!
SOURCE: 1996 sunfire with no spark
Change your coil pack. If you want to save money, go to an auto wrecker and get one. Don't be afraid of used parts. You drive on them every day. Might as well grab a mass air flow sensor while you're there.
SOURCE: 2002 pontiac grand am, new fuel pump and filter, wont start
Is the security light active? If yes it will have to get reprogrammed by the GM dealer as GM has this as a propriatory system... Meaning no one else can work on it.
SOURCE: 92 Firebird 3.1 L engine wont start many items checked replace
Ill buy it.=D i have a wrecked car but the engine and everything in it is perfectly fine. it will fit into your car and everything.
car wont start
