How to bleed brakes
to bleed brakes is a relatively easy job for two people although it can be done by one without a pressure bleeder.NOTE keep brake fluid levels above minimum at all times during bleeding ( forgot to do it my self on more than one occasion and had to start over, trying to do too much at once) To do by your self you will need the correct ring spanner for bleed nipple, a clear tube that is a tight fit on bleed nipple ( long enough to reach down to floor) and a container with about an inch of brake fluid in it (glass jar will do it, is easier to see fluid level), Starting with the cylinder/caliper at rear furtherts from master cyl (longest brake line from tee piece) place spanner on bleeder then fit tube, placing other end of tube into container below level of fluid,. release master cyl cap/lid (no need to remove completely) undo bleeder half a turn, watch for fluid in clear tube. this should start to flow within 10 to 15 seconds (if bleeder isn't blocked with road grime clean if required), if fluid doesn't flow by it self (it should but) tighten bleeder then release again quarter of a turn, apply foot pressure to brake pedal, hold pressure on pedal till you feel pedal dropping towards the floor (half inch of pedal travel should be enough) ( fluid in container will stop air being drawn into brake lines when you release brake pedal) check clear tube for fluid/bubbles, open bleeder further quarter turn, if fluid has filled clear tube allow fluid to fill container a further eight of an inch, then close off bleeder (make sure no bubbles appear in tube whilst this is happening other wise drain more fluid till only brake fluid is visible in tube ) repeat process on opposite wheel cyl/caliper, then repeat process on front caliper furthest from master cyl , then the caliper closest to master cyl last. If two people are doing the bleeding the same clear tube and container are used,as is the order in which cyl/calipers are bled. One sits in the car and pumps the pedal until it has some resistance under foot (Whilst the pedal is held down) second person releases bleeder, first person keeps pressure on pedal whilst bleeder is released (pedal will travel towards the floor) when pedal has been depressed as far as it will travel second person closes bleeder before, the first person releases pedal and pumps the pedal again repeating the process until no air bubbles appear in clear tube at this cyl/caliper before moving to next cyl/caliper. good communication must be maintained to make this process hassle free
