1990 Toyota Corolla Logo
Posted on Dec 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cut harness from stereo in 1990 corolla dx sedan
While trying to be mcguyver and install an aftermarket radio in the car ive cut the original harness for the car and cant figure out the color codes for the radio...also my interior lights(dash/dome/etc) will no longer come on.
  • Mike Butler
    Mike Butler May 11, 2010
    Cut into a fused wire maybe? Have you got a 12vdc test light, or multimeter?
Marvin
Level 3:
Top Expert:
  • Toyota Master 85,242 Answers
  • Posted on Dec 19, 2008
Marvin
Toyota Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060632
Points
266281
Did u know that they make a harness for your car that plugs into your factory harness and then adapts to your aftermarket radio? for the lights, you have blown the interior light fuse, it may be the same fuse as the cigar lighter.Below is your radio wire colors and what they do.
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: 4′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Anonymous
Level 2:
Sergeant:
  • Expert 233 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
233
Questions
6
Helped
104373
Points
555
You have blown your Horn/hazard fuse in the under hood fuse box.
do you have any technical experience, do you know how to use a meter or test light?
here is the wiring for your car.. remember to insulate all wires and check the horn/hazard fuse and the radio fuse, also the Dome fuse..Check all fuses JUST to be sure!
Constant 12V+   Blue yellow   Switched 12V+ Gray   Ground    Brown
Illumination Green
Dimmer n/a
Front Speakers
Left Front (+) Pink  Left Front (-) Purple  Right Front (+) Light Green  Right Front (-) Blue
  Rear Speakers
Left Rear (+) Black  Left Rear (-) Yellow  Right Rear (+) Red  Right Rear (-) Whi
1982 Oldsmobile Delta 88 Royale. The radio is missing and the connector going into the radio has been cut. I need to know where or what the color coded wire are coming from like the speaker or what?
Question edited for clarity.
Question moved to model category.
Your Question posted as an answer to another Post, deleted.
1984-85 Oldsmobile Delta 88 Stereo Wiring - The 12 Volt
the12volt.com https://www.the12volt.com > installbay > stereodetail
1984-85 Oldsmobile Delta 88 car stereo wire colors, functions, and locations.
Missing: 1982 ‎' Show results with: 1982
Oldsmobile Wire Diagrams and Wire Codes
Car Stereo Removal https://www.carstereoremoval.com > htm > WireCodes...
With aftermarket stereo installation? GM Wire Harness Diagram, Wire Color Codes and Pin Configuration, Wire color codes and wire diagrams.
Wiring diagram to replace radio in a 1990 delta 88?
Fixya https://www.fixya.com > Forum > Cars & Trucks
Apr 9, 2009 - Wiring diagram to replace radio in a 1990 delta 88? - Cars & Trucks question.
1986 Oldsmobile Delta 88 Car Stereo Wiring Guide
modifiedlife https://www.modifiedlife.com > 1986-oldsmobile-delt...
Our automotive wiring diagrams allow you to enjoy your new mobile electronics rather than spend countless hours trying to figure out which wires goes to which ...
2answers
98 Acura cl 3.0 original stereo OEM wires were cut installing aftermarket stereo what are the color codes on the original stock harness so I can route it to the new wiring harness kit
read (you meant main harness to radio sub harness.)
and car may have 5 or more harness for 5 or more very complex radio head end options new,so only the real service manual covers all that for sure,or if lucky 2nd fiddle here.
https://eautorepair.net/Marketing/Default.asp
I have a 2001 toyota corolla got the 1.8 L. The car came with an aftermarket radio but only the back left speaker is working well cause of my experience in installing car stereos I pulled the radio and...
Sound test/click test each speaker with a flashlight battery at the radio end of the harness. Hold the ground of battery on metal frame or ground wire and touch the speaker wire to the hot post of the battery. If speaker doesn't click click/static, speaker is bad or harness not connected to speaker. If each passes the test and clicks, your speaker control on the radio isn't working. Being a stereo installer you should know this, or possibly forgot to do so. I've neglected to do the same for the "hurry" mode had kicked in.
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
1helpful
How do i take out my radio from my toyota corrola
The Toyota Corolla has been around long enough that many owners find themselves needing to replace the factory stereo. Installing a new stereo in the Toyota Corolla gives improved sound and updated features. Swapping out the stereo in the Toyota Corolla takes basic tools and less than an hour. This article covers models from 1990 to 2000.
Open the hood and remove the negative battery cable from the terminal. Apply the parking brake and place the car in "D."
    > Remove the trim from around the stereo by prying with your fingers at one corner. Some early models have two screws at the top of the trim piece to remove first. Allow the trim to hang on the drivers side of the dash if it's connected to the cigarette lighter.
    > Locate and remove the four screws holding the stereo in place. Pull the radio out of the dash and disconnect the wires from the back of the head unit.
    To install
    > Connect the wiring harness adaptor to the original harness and let it hang from the dash. Slide the new stereo into the Toyota radio mounting kit, which is a thin metal cover and secure it per the manufacturer's instructions. Most adaptors have screws to hold the stereo in place, however some have clips, which engage automatically.
    >Plug the wiring harness adaptor and antenna wire into the back of the new head unit and push the entire assembly into the dash. Reconnect the negative battery cable and turn the radio on.
    > Ensure all of the stereo controls and speakers are working. Secure the radio in the dash with the original four screws and replace the trim.
1990 toyota corolla stereo wiring codes i just purchased a sony stereo and i took out the old radio in my 1990 toyota corolla but i cant figure out how to connect the wires i need the color code for...
what you need is to buy a wiring adapter for your car.it only cost about 15 bucks and plugs right in to your original plugs that were connected to your factory radio.the great thing about this adapter is that you dont hava to cut your original plug off just in case if you ever want to reinstall your original back.also the wires that go to your new headunit are color coded to match the exact colors that you connect to your stereo.you can't mess your connection up because all you have to do is connect each wire to the right color,tape them up,connect your stereo and you have music with all of your speakers working like they should and without any headaches.i hope this info helps.take care and good luck, manny
1helpful
I am trying to install an aftermarket cd/radio into a 2001 Toyota Corolla GS which has a standard radio console
I would get a stereo installation kit for your car from Auto Zone or a local car audio store. It will have the surround for the new stereo to fit where the old one was and a harness that you can wire the new stereo to and the harness will have a plug to match the stock radio plug.
1helpful
How do i remove the radio
there are 2 phillips head screws right above the the cassette holder or that little compartment right over the ash tray that have to be removed.after you take those 2 screws out,you will have to pull off all of the heater control/a/c buttons off then pry off the the plastic frame that covers the radio because it is held on with clips.if its a little hard,u can try and pry it off with a flat head screwdriver,but not too hard cause you can damage the dash pad by doing it too hard.after you get the cover off,there will be 4 more screws holding the radio in place.you can either use an 8mm socket or a phillips head screwdriver to remove these 4 screws.if you are planning to install an aftermarket stereo in your corolla,you can use the same brackets from your original radio to install it perfectly and tightly.everything should fall right in place.to avoid any wire cutting,buy a universal stereo plug which runs about 15 or 20 bucks but its well worth it and if you ever want to reinstall your original stereo back,all you have to do is unplug and plug.no wire cutting at all.hope this info helps.take care and good luck, manny
2helpful
2answers
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
Radio connection
if he had an aftermarket stereo in the vehical then he had to cut the origional harness out of the way. the only solution for this would be to replace with another aftermarket stereo. I know this becaus ei had a ***** of a time trying to install my aftermarket.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
