First I would need to know the model Bluetooth you have so I could tell you what to do to reset the headset. You can always reset a bluetooth headset to repair it to another device. Normally though to reset a bluetooth headset, you would have to power the Bluetooth device off and then press and hold the device to get it in pairing mode. Usually when in pairing mode the device's light usually stays lit a solid color such as red or purple, or it flashes two different colors simultaneously. At that point you can get your device to find the headset (make sure that you device is bluetooth capable, is on, and is visible to devices) and then pair it. There is always a passcode or pin associated with the headset which creates a secure connection between your device and your bluetooth headset. The default pin code is 0000. Hope you get it working, if it doesn't shoot me a message with the make and model of the bluetooth headset and I can walk you through it.
It Will connect to any phone with Bluetooth as long as it works
