I got my Motorola H350 headset after a friend of mine tried to connect it on his nokia mobile, i tried several times to connect it on ma n80 mobile but the phone wans'nt able to see the headset. is the headset need to be formated to be able to connect on my phone, or what exactly the problem and how can i fix it? Thank you.
You can reset any bluetooth headset by pressing the volume key and the power key pressing them simultaneously for few seconds and it will be resetted. TO connect with any other bluetooth mobile press the Power button of your headset while your mobile searches for bluetooth headset. when it asks for a pass key use 0000. now you can get connected. try this...........
YEAH!!! the reset function worked with my bluetooth headset!!! I have the motorola h350 with a Sony Ericsson 710i. The reset function is to hold both volume button and the talk button at the same time for a couple of secons(~ 6 sec), after that my phone was able to connect to it! Thanks.
There nothing in the 2 pages manuel for reseting the device! Reallly stupide thing! Because there no batterie to disconnect...
It worked for me. Thanks
If resetting the bluetooth headset doesn't work and still people cannot hear me, tho I can hear them, and all settings are correct on Skype and my Powerbook, does anyone have any other suggestions. As this is my telephone and I cannot call out, tho I can listen to and receive messages.
Thanks so much for the bluetooth tip britusr!!
I have recently adopted Airtel and the connection of AIM is not available and network connection required. The mobile was presented to me by my relative and the code numbers to open or close the mobile is not known.. What should I di ? Surender
I had a similar issue with my Nokia E65. The solution was to wait a little while after entering the code. If i added the device as authorized while the blue light flashed quickly then it would fail to connect after the pairing... hope this helps
To reset was a great solution for me I had lost my instuctions and could not pair my bluetooth so I serched the web and the answer was found thank's to you i now have my bluetooth back
Cathy
SOURCE: how do I connect my h350 motorola bluetooth with my nokia 6275
I tried so many diff codes, every saying 0000,who doesnt try 0000? its always the 1sy 1 u try,anyway my Razor connected in the end with 1111,hope its more helpfull. Lee S.
SOURCE: how do I connect my h350 motorola bluetooth with my nokia 6275cel
Try video instructions on connecting Bluetooth headset to Nokia phones on www.HandBookLive.com under Electronics category (Motorola H710 headset). It should be pretty much the same for all headsets. Watch chapter on Pairing phone to headset (Nokia example) It shows you the steps and what the phone screen will look like on your phone as you go through the steps (activating Bluetooth option on the phone, then searching for devices (headset) and finally pairing the headset with your phone.
I have the same problem but my motorola is H700
I have a MotoRokr E6 mobile n a Jabra BT 135. My mobile is not detecting my headset device. Have tried a lot. Pls help me out as a totally new user for bluetooth headset n explain in details.
Thank u,
Neil
The problem is same but the phone model is diferent.(nokia 6300)
I CAN'T GET MY BLUETOOTH TO CONNECT I TWAS BEFORE AND NOW IT WONT. THE CONNECTION JUST GOES AND GOES BUT NEVER CONNECTS.
i have a h700 and when i try to locate it i says no assigned name. when i try to enter the 0000 pin it says password miss match. i have a lg cu920.
