Hi
I have this unit and see the message many times. What I do is take the head unit and plug into USB on computer for a few hours with screen switched on. It gets quite warm, I guess charging OK. Back in the car, no more message! For a month or two anyway... So it does not charge too good in the car, could be too many recycles, low voltage, don't know, but this works for me.
Did you get an answer to this? I have the same problem but now live in Malta!!!
SOURCE: Pioneer gps avic-n1, avic - N2
I am sorry to inform you that the program you are using does not specify between personal vehicles or commercial vehicles.
This unit was created for use in personal cars and trucks without taking RV's into consideration. Pioneer should have thought about this when they designed the program, because I am sure you are not the only person who has ever put one in an RV.
I checked the service manual and found no reference to anything about commercial use and routes.
I guess you will have to pay very close attention to the signs on the road that display the clearance of low overpasses. There is a good chance that any route you may take will have a sign posted with the clearance and with enough time to be able to make any needed adjustments in your route.
Good luck, be safe, and if there is anything else I can assist you with don't hesitate to ask. I am hear if you need me. I work at an authorized Pioneer repair center, so I have access to just about everything Pioneer makes available.
Just so you know, if your unit ever needs service, this is one of very few that Pioneer does not authorize any of there authorized service centers to repair under warranty. They must be shipped to Pioneer, no exceptions. If it is not under warranty, anyplace can work on them, but it might be difficult getting some of the parts.
SOURCE: AVIC-N2 AM fm radio XM radio Backup camera
Check the connections at your brain, you probably pull it loose when you removed the N1. Goodluck.
SOURCE: disc read error
I do have the solution, I paid for the information but I will forward it for free just send me your email address, it really does work if you follow the instructions carefully. My email address is [email protected]
