Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
REVERSING DOOR SWING
Your
dryer is designed so the door swing may be reversed at any time without
additional parts. Conversion is accomplished by transferring hinges to
the opposite side of the cabinet.
To change the direction of the door opening:
1.
Open the dryer door. Remove the four hinge hole plugs from the left
side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Are you planning to reverse the door swing direction on your DUET®dryer? To do so, you will need to purchase a Door Reversal Kit. To order, call the dealer from whom you purchased your dryer or refer to the "Assistance or Service" section of this manual. Ask for Part Number 8530069 (Shield Blue), 8530070 (Shield Platinum), 8530071 (Biscuit) or 8530072 (Pewter). Door Reversal and Stack Combination Kit Are you planning to reverse the door swing direction on your ® ® DUET dryer and stack your DUET washer and dryer? To do so, you can purchase a Door Reversal and Stack Combination Kit. To order, call the dealer from whom you purchased your dryer or refer to the "Assistance or Service" section of this manual. Ask for Part Number 8530073 (Shield Blue), 8530074 (Shield Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
