Dryers Logo
Question about Indesit Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
Posted by richard949 on
Anonymous
  • 314 Answers
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Posted on Dec 21, 2010
Why when my door is open on my indesit idc75
The door switch is probably stuck in the "door closed" position. I presume the light inside also does not turn on.
Oct 05, 2014 • Dryers
Headlight condensation
Try by using a hair drier. Remove head light assembly from vehicle. Remove the bulb for the head light, Use the hair drier through the bulb hole to remove condensation. If water gets in the head light. Drill a small hole on bottom to release the water. Some times you can remove the condensation from the head light if its not bad by using the drier on the outside of the head light, with out removing it. Good-Day!
I have an Indesit Dryer IDC75(UK), the red light goes on but the Container is empty, therefore it takes longer to dry and all the condesation collects inside at the rear bottom of the machine, I have...
Most likely it is clogged vent and also check for outside vent
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
1helpful
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 • Dryers
1helpful
No heat coming from drum when spinning with our indesit idc75 drier can u help? looked for reset butten but cant find one can u please help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 15, 2011 • Dryers
1helpful
2answers
I have an IDC75 condenser dryer. Everytime i press the start button to start drying my clothes, it will not allow me to start it and immediatley shuts off the electricity in the whole kitchen. PLEASE,...
the culprit seems to be the CONDENSER BOX. This can quickly get blocked up by soggy wet lint/fluff debris from clothes. Some clothes shed more than others, so it is best to check this frequently. What happens is that when the CONDENSER BOX gets partially blocked up, it fails to condense the steamy moist air into water efficiently, and the insides of the drier start to get damp ans steamy. Depending on the amount of moisture, and the make (Some Zanussi and Hotpoint driers may be vulnerable to this), if any vulnerable electrical part get too damp, then there will be a "flash-over" between a live component and neutral or earth (usually a part connected to the casework). This can cause the kitchen circuit breaker to trip. The fix: remove your condenser box, and give it a good spray clean in the garden with your garden hose. Any large lumps of fluff/lint that are stubborn can be pushed out from between the condenser slots with a plastic ruler. Allow to dry. Then , with power removed from the drier, use a good flashlight checking that there has not been any build-up of fluff behind the condenser box area at the rear. You may need to remove the water tank as well to see more clearly. It is worthwhile also checking the little buffer-tank at the back, where there is a level sensor switch for the water tank level. If it is full of gungy water and lint, try to give it a clean out. Give your machine an hour or 2 to dry out internally a bit before attempting to dry any clothes, in case the breaker goes again. If it DOES go again, try leaving it for linger. If it still fails after being left for 24 hours, there may be a more permanent fault, inside the top back of the dryer there should be a wiring diagram(might be on the back panel of dryer) you will need to trace wires and with multimeter try to figure out what is causing the short. Hope this helps Tim
2helpful
I have an indesit is70c condenser drier and it doesnt seem to be collecting all the water in the water container. some seems to make it into the container but then the rest just sits in the container...
To take the lid off, remove the two screws at the back and slide the lid backwards. If you try to lift the lid up, you will break the plastic catches. I learnt the hard way. If you do it correctly, it's easy.
At the back of the tray that holds the water container there is a small hole which allows access water to drain back down into the pump. Clean this hole(it will probably be full of fluff and hair). While you are there, there is two tubes at the back off the drier the thicker on of the two is the one that the access water drains into, make sure this is not split(mine was and I used self amalgamating tape on it to seal it again.) Replace lid, replace water collector, job done.
Jan 19, 2010 • Dryers
2answers
Condense Pump on TM310W
remove the side panles, an locate the pump. Then look if you can get it out without removing the backpanel.
1helpful
Indesit IS70c condenser dryer
CHECK PUMP AND FLOAT AT REAR OF DRYER EITHER PUMP IS BLOCKED OR PIPE FROM PUMP BUT MAKE SURE THE DRYER IS UNPLUGGED WATER AND ELECTRIC DO NOT MIX,
IF YOU ARE UNSURE WHERE TH PUMP IS GET A QUALIFIED ENGINEER
Dec 25, 2007 • Dryers
Top Indesit Dryers Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
W.L.
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
