Car temp heats up between 195-235 degrees, blows air cold , new thermastat 195 % installed, coolant full, heater core not bypassed please help my daughters CAR
Okay. warm up vehicle, get radiator hoses hot. Turn on heater, fan on low. Grip both rubber heater hoses close to the firewall, from the engine compartment side. They should be too hot to hold for long. If they are not hot, then you have a lack of coolant circulation to the heater hoses. If they are hot then access heater core, behind glove box area. Blend door which moves as you chose HOT or Cold, should be cable controlled, move the controls and be sure the door is actually moving. Keep me posted
PUT WATER IN RADIATOR!!!! IT HAPPENS TO ME ALL THE TIME!!!
thermostat new, still blowing cold air engine will over heat. no water in oil, water blows out over flow
