Mercedes c200
If you have a trailer plug in the rear of the vehicle, power can be feed into the correct terminals to allow for electric things to work. Also, the interior power outlet for the cigarette lighter can be used as a port to feed in power with any cigarette power lead. Just be sure to use the negative with the same polarity.
For that matter, if the interior is accessible, you can uncover the fuse panel and feed power into the fuse block. Any 12Volt battery will provide enough power to open the boot.
SOURCE: mercedes/dead battery can't open trunk help
There should be a positive charging post under the hood. Hook up jumper cables to this post for positive and the engine for ground. Then get in the car and pop the trunk with the trunk release button.
SOURCE: battery is dead and can't open the trunk, even manually
Starter motor on this car is imposible to get to..better find the post forward of the drivers side fuse box in the engine compartment where a bunch of wires come together. This is a positive terminal attach red jumper here put the negative jumper on any bare metal bracket of the engine
SOURCE: my mercedes clk battery dead i cant open trunk
On the side of the smart key there is a mechanical key that slides out of one of the sides-There should be a little release lever retaining the mechanical key. It can be inserted into the trunk lock and turned to open the trunk. There are several other positions the key can be turned to place the trunk lock actuation in different modes- it should be in your owner's manual Hopefully I have been helpful
SOURCE: MY WILL NOT START THE CAR C240 MERCEDES BATTERY IS NOT DEAD
I am assuming that the engine won't even turn over. could be lots of different things. The simplist is to make sure the car in in PARK , won't start if not. Other things could be , Security imobilizer if you have one. Does your key have a electronic chip in it ? Try your other set of keys if you have one. Check if battery connections are clean and tight.
