Start capacitor
SOURCE: the fan is not movien on my trane high efficienct
If you are sure that the unit has power, look for the capacitor. A run capacitor will be oval shaped with a rupture disc on top. If it is ruptured then the capacitor needs replaced. If it is a round one, the top will be bulged and it will need replace with an exact match. There is a combination type that says fan and herm on it and it can be either of the first two mentioned. If this is not the problem then replace the fan with and exact match
SOURCE: Problem with capacitor of air conditioner?
the ratings of the capacitor should be on the capacitor itself in mfu sounds to me like the compressor stuck and cycling on overload is the capacitor distorted or swollen
SOURCE: where is the capacitor located in a trane central
the cap and all other electrical components are safely placed inside the unit's box. You have to take the side off of the unit and the metal box is on top please throw the disconnect of and remember there is still 24 volt live inside. The 24 volts is coming from the furnance.
SOURCE: Why is my fan motor on my trane air conditioner
Check the capacitor for the fan. Has the fan been replaced recently? If so make sure the start lead is connected to the capacitor.
SOURCE: Air Conditioner comes on but
First mark the wires and make a diagram so you can reconnect it. Next remove the capacitor. You can take it to a heating and air supply and they will test it for you. They will also sell you a new one. Use your wiring diagram to reinstall the capacitor wires. It sounds like your problem is the capacitor.
