Lincoln Conveyor Oven - 1133-000-A Logo
Posted on Dec 13, 2008
I have a lincoln impeger pizza oven and it wont come on
I know it has both internal and external reset but i dont know where it is
Illassist
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 25, 2009
Illassist
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
11786
Points
21
The oven temp high limit is on the back. Depending on model there is a control box high limit that you need to open the control box and locate. If this is the case, make sure the cooling fans are running.
2answers
I have a licoln 1000 pizza oven it will cook outside of pizza not bottom why
check the fingers especially the bottoms ones , they could be clogged with dirt or pizza particles. just clean them
2answers
I have a Lincoln Impinger pizza oven that won't
Yes, it could be, because the heating element is OK
Mar 22, 2013 • Ovens
Need wiring diagram for a Lincoln 1000 hp pizza oven
What circuit for impreger converyer pizza machine
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Does lincoln 1450 series oven do the same job as lincoln 1000 ovn
The 1450 Lincon and the 1450 digital basically does the same things only that the digital is more advance in that it is has mother board whith digital control. it is more acurate in its sttings eg acurate time and acurate temparature setting. It also can give diagnostic massages within the control.
As for your lincoln 1000 series please try and give me the detailed problems, im sure i can help cause i have over 8yrs experinces with lincoln pizza ovens
I got a 1301 208v the fan blows good but it does
If threre is no alarm please make sure that the gas inlet pressure is ok or contact me at [email protected]
Lincoln pizza conveyor oven
have you checked the speed control?? it maybe off on the speed run some empty pans thru and time each one I will need a model to give you the entry and exit times for your model before we can futher. do it 3-5 times let me know
Dec 03, 2007 • Ovens
Top Lincoln Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
