Hl dt st dvdram gsa t20n ata device error code 10.
System says it has the most updated driver but will not "start".
SOURCE: HL-DT-ST DVDRAM GSA-T20N ATA Device
try this ..
you must start regedit ( start -> run [See screenshots at the bottom] Type here: regedit )
search the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/
search for "4D36E965-E325-11CE-BFC1-08002BE10318"
if you doesn't find anything, search only for a part of the string.
now search the propertys UpperFilter an LowersFilter and kill the value. If only one prop. is there, you must kill only the one value
on my laptop it works!!
http://www.computerhilfen.com/hilfen-26-186214-0.html
cheers ...
SOURCE: HL-DT-ST DVDRAM GSA-T20N ATA DEVICE driver error code 39
Hello Matoooon,
Run this following fx and then restart the notebook, the DVD drive will start working normally.
http://www.jasonross.name/files/CD_Drives/CD-Drive_Fix.reg
Try running System Restore to a day just before this failed. It's a software issue according to other forum posts elsewhere.
SOURCE: I HAVE HL-DT-ST DVDRAM GSA-T20N
Dear Sir,
Please port details questions to help us to serve you better.
I assume you are getting error code 10 which means DEVICE CANNOT START. For solving this use your driver CD, supplied with the DVDRAM. And check from device manager that the device is enabled.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
SAME THING ITS SO FRUSTRATING HELP!!!!!
I also have the same problem. I am hating VISTA more and more everyday.
