20 Most Recent
Intel Durabook V38263 Notebook Questions & Answers
I still can't get my Fn key to unlock. I've tried
Change your keybord layout in control panel->regional settings.
Then if still same thn your laptop keybord has issue because anothr usb keybord works fine.
There is not issue with operating system you need to repair your laptop key bord.
If it is warrenty you can use warrenty
Let me know if you need further assistance.Thanks for using fixya.
How do i enable my wi fi on my durabook laptop
Make sure you pressed the wireless button. On my durabook it is located to the right of the power button. It should turn green. You can check you network status to see if you are connected, or what wireless networks near you are available. Secured networks need a key.
HL-DT-ST DVDRAM GSA-T20N ATA Device
I read over the solution to the problem by deleting the lower keys in the registry,,restarted and it works fine again,,thank you.
The 1st time I tried it, there was now upper or lower keys because i had uninstalled the driver 1st.
My laptop has no audio output device and playback
Hello....
No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with all Windows OS updates....many of the users are facing this issue....this began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service and help everyone affected by this stupidity from Microsoft.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots....visit my support page.
all the best...
The screen went out
Pull the hard drive out, get an EIDE / SATA to usb adapter at a computer retail store. This will allow you to hook up your hard drive to another computer by pluggin it into a usb port. The computer will then read the hard drive as an external drive. You can then access all the files and copy what you want.
You could get a vga cable and hook the laptop up to another monitor or a tv that has a vga input. This way you could use the tv or monitor as an external and get yourself an external hard drive to copy your files.
The next thing you can do is look for a screen on ebay and buy an lcd panel, On most laptops, there are rubber covers over the attachment screws, then the bezel snaps off the frame. Unplug the inverter on the bottom, remove the tiny screws holding the screen to the sides of the hinge arms, unplug the flat video cable on the back, take the screen away and pop the new one in place.
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock.
Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire.
Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
Intel D865GVHZ Motherboard won't boot into anything but will turn on
If your Intel D865GVHZ motherboard is not booting and you've tried replacing the CMOS battery, resetting it, reseating RAM, and changing the PSU, it may indicate a more serious hardware issue. You should consider checking the following:
1. Check the monitor: Ensure that the monitor is functioning correctly by trying it with another computer.
2. Check the connections: Verify that all cables, including the power and video cables, are securely connected.
3. Inspect for hardware failures: Check for any visible signs of hardware damage or loose components on the motherboard.
4. Test with minimal hardware: Disconnect all unnecessary peripherals (e.g., external drives, graphics cards) and leave only the essentials connected (CPU, RAM, power, and monitor) to rule out any conflicts or faulty hardware.
5. Try a different RAM: If possible, test with different RAM modules to rule out faulty memory.
6. Listen for beep codes: If your motherboard has a speaker, listen for any beep codes during startup, as they can provide clues about the issue.
7. Inspect the CPU: Check the CPU for any damage or bent pins, and ensure it's seated correctly.
If none of these steps resolve the issue, it's possible that your motherboard or other critical components may have failed, and you may need to consider a replacement or professional diagnostics to pinpoint the exact problem.
Smart response technology
Intel Smart Response Technology (SRT) is used for SSD caching to improve system performance. To use it successfully, here are some steps to consider:
1. SSD Compatibility: Ensure that your SSD is compatible with SRT. It should be a SATA SSD.
2. BIOS Settings: In the BIOS, set the SATA mode to RAID (not AHCI or IDE) before configuring SRT. Make sure your motherboard supports SRT as well.
3. Driver Installation: Before enabling SRT, install the latest RAID drivers provided by your motherboard manufacturer.
4. Backup: Backup your important data because enabling SRT involves data migration.
5. Enable SRT: In the BIOS, set the SRT mode to "Enhanced" or "Maximum" depending on your preference.
6. Initialize SSD: Initialize and format the SSD through Windows Disk Management.
7. Install Intel RST: Download and install the latest Intel Rapid Storage Technology (RST) driver and software for your chipset.
8. Enable SRT in RST: Open the Intel RST software and enable SRT. You should see an option to accelerate your HDD with your SSD.
9. Reboot: After configuring SRT, reboot your system.
10. Verify: Check if SRT is working by opening the Intel RST software. It should show your SSD as a cache for your HDD.
If you're encountering crashes or issues, it's essential to ensure compatibility and follow these steps carefully. If the problem persists, consider seeking assistance from your motherboard manufacturer's support or Intel's support, as it could be related to specific hardware or software conflicts.
