Excessive flooding
Yes you can but may cause problem with cold starts.. is the black plastic choke thermostat adjustable? if so loosen the 3 flat head screws, do not remove them,, rotate choke thermostat counter clock wise until you see the choke butter fly start to break open.. stop and turn back clockwise about 1/4 of a turn.. that should give you just enough choke to start cold engine
SOURCE: Toyota 22r starts hard and floods. Repalced
It sounds like the carb. float is set to high and /or the needle and seat has some dirt in it allowing to much fuel inside the carb.. This will allow to much fuel into the engine.It seems the carb could use a rebuild and dont forget to replace your fuel filter.I hope this helps.
SOURCE: Toyoat Hard to start
I recommend to remove carb and send to a specialist to have rebuilt or reconditioned. Cleaning it may not be enough. A carb that old may need to be serviced. This would be your starting point. The service shop can test it "outside" of vehicle.
SOURCE: i have recently rebuilt the single barrel carb on
Check the two screws / pins on the side connected to the air / gas flow levers. The screws go into and out of the carb and / or rods itself. Just play with it and hope you didn't leave anything out!
SOURCE: 1981 chevy pickup with a carburated 305 is hard
Is the choke operating properly? You say the current carb has an electric choke, so I am assuming the original carb did not have an electric choke. If that's the case, have you wired the electric choke to a power supply?
