With new application " 2.0.3.16 " I cannot record video stream,it shows " cannot capture video stream ".But after uninstall and use original app. in cd came with card,it works correctly.So why?
SOURCE: HOW T DO I CONECT A VHS VIDEO RECORDER TO MY WINFAST TV 2000XP EXPET TV CAPTURE CARD ?
Your VHS recorder has a Coaxe output! So does your card the sound will be replicated there as well, now it would not hurt to get a capture card that has those plugs as you rendering would be much more prestine. Pluag you VHS into the coaxe input on your card set the channel to 3 and you got it bud!!!
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: tv-tunner cannot render audio capture stream
What cable connections are you using? HDMI has to be enabled on you motherboard (high def. audio), if its S-Vidio you must run a seperate and dedicated audio cable from headphone jack to TV.
My first gues would be to right click your audio icon on your desktop toolbar and check your playback and recording settings, make sure the tuner card is the source, hope this helps!
This solution is only applicable for the selected camcorder models. You can follow the steps mentioned below for the DCRHC36 models.
Only the USB driver included on the supplied CD-ROM will properly enable the camcorder for USB streaming. The USB Streaming Driver can only be installed from the supplied Software CD.
o NOTE: The computer must have compatible video capture software to complete this procedure. Many video editing software applications include a capture function. If you have video editing software, you might not need a separate video capture application.
Good Luck
FixYa
