2000 Mitsubishi Mirage Logo
Anonymous Posted on Jun 27, 2012
2000 Mitsubishi Mirage--Changed battery, code displayed on car radio screen; played with entering numbers, pushed the audio button, now OFF is displayed. What to do?
  • Anonymous Jul 01, 2012
    Thank you for the speedy response. I was able to locate my code and get the radio playing again! Before entering my code, days later, the word "OFF" was no longer displayed on the screen. "CODE" was displayed again and I was able to properly enter the correct information and follow the steps according to the directions in my vehicle's manual.
    Oh yes, owners, if you run across this problem (entering the wrong code numbers and the radio displays off) give it some time; maybe a day or three allowing the system to display "Code" again, then enter the codes the way the car manual states it. It will work again. Don't run and purchase a new radio.
Hector L. Morales
Level 3:
  • Mitsubishi Master 649 Answers
  • Posted on Jun 27, 2012
Hector L. Morales
Mitsubishi Master
Level 3:
Answers
649
Questions
0
Helped
243265
Points
1923
If you entered the incorrect code several times you may have ruined your chances of getting radio to work. On vehicles with anti theft radio when the battery is disconnected or the vehicle looses power the radio licks and to enable it a code is needed. The dealer may be able to help you but they would need certain information. Sometimes the vin of the car or some times the radio has to be removed to get the serial number. But if the wrong code is entered after so many attempts the radio becomes completely disable. To the point where you will not be prompted to enter a code.
5 Related Answers
Anonymous
  • 64 Answers
  • Posted on Dec 01, 2008
SOURCE: I need a radio unlock code.
you have to call Mitsubishi and give them the serial # and model # on the radio . they will look it up in the computer ans give you the code
Anonymous
  • 152 Answers
  • Posted on Jan 01, 2009
SOURCE: Radio Code for 2000 Mitsubishi Mirage DE
you can take your car to any Mitsubishi dealership (service department) and ask for the code. Usually, they will ask for identification to verify you are the owner of the car. This usually just includes your drivers license and registration card. Sometimes, the dealership will want to physically see the car before they give you the code. But if you don't know the code, the dealership is the only place to get it. Your owners manual will give you the procedure for entering the code once you get it.
Anonymous
  • 74 Answers
  • Posted on Aug 08, 2009
SOURCE: radio displays off after three separate attempts to put in code
radio has a four digit code to be able to work,if you do not have the code,you will need to pull radio out and copy serial # on radio to get code from dealership,after you get code turn ign.switch to on position(do not start car)for about an hour or until code appears on display ,enter each code number with ind. station buttons it should come on if it does not enter code again but after last entry hit cd button,you will get 3 attempts before radio goes into failsafe again
Anonymous
  • Posted on Sep 23, 2009
SOURCE: I have a 2000 Mitsubishi mirage and I had to
Its just a radio code which I managed to enter some numbers. Thanks
Anonymous
  • 478 Answers
  • Posted on Feb 10, 2010
SOURCE: nede code for tehe radio mitsubishi mirage 2000
musst contact dealer and have them reprogram it or a auto radio shop
2helpful
How to insert the code for the radio of my golf3 /1996
ENTERING SECURITY CODE
Most vehicles are equipped with Heidelberg V or VI radios that are equipped with a theft protection program. When the battery has been is disconnected or if the radio has been removed, the radio will lock-up electronically and cannot be operated until the security code is entered. On the Heidelberg V, if the proper code is not entered in six attempts, the radio will lock-up permanently and cannot be repaired. On the Heidelberg VI, two incorrect attempts will lock the radio for about 1 hour.
The Heidelberg V may have a code assigned at the factory or a personal code created by the owner. The Hiedelberg VI has a code assigned at the factory and entered by the dealer during pre-delivery inspection. New radios come with the code printed on a sticker but not entered into memory. All codes are 4 digits. To code the radio:
Heidelberg V
  1. Turn the radio ON . The radio should display the word SAF. DO NOT attempt to eject a cassette with the radio in this mode.
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear for about 3 seconds, then the display will go blank. Release the buttons then.
NOTE If the buttons are held too long, the radio will interpret this as an attempt to enter an incorrect code.
  1. Use the first four station selector buttons to enter the code. The first digit of the code is always 1. Each time the other buttons are pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When the radio plays and displays a frequency, release the buttons.
  3. If the code was entered incorrectly three times, momentarily disconnect the battery and try again. If the code is entered incorrectly three more times, the radio cannot be coded and cannot be repaired.
Heidelberg VI
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear and remain in the display.
  1. Use the first four station selector buttons to enter the code. Each time a button is pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When SAF appears in the display, release the buttons. The radio should play and display a frequency.
  3. If the code was entered incorrectly two times, leave the radio ON for one hour and try again. This can be repeated as often as required.
I have the radio code ... what is the procedure ?
Okay, lets start with if you tryed entering the code and you did it three times the radio will lock so if you turn the key on and the radio and the screen says lock then you will need to unlock it, this is done by turning the key on and also the radio, this must stay for about one hour i recommend letting the car idle to avoid draining the battery, but radio must stay on for one hour and not in the acc postion so to avoid mistakes let car run, you will know its ready when you see ------ on display. if your radio is displaying--------- then you are not locked out and you can just enter the code, sit in seat and have your code from left to right you will enter the first to numbers using the radio seek button you will enter the first and second code,push the leftside of the seek and then push it to right side and you will see the code 3 change then for the next two numbers of the code you will do the same with the tune button when the code is displayed then push the am/fm button and radio will come on. good day
I changed my battery on my Audi A4 2000 2.4 the radio now shows safe mode. I got the code in my manual(written down by previous owner) but cant remember what the procedure is ?
The sequence of Audi radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
2answers
Radio displays off after three separate attempts to put in code
1helpful
Radio code
GETTING THE RADIO SERIAL NUMBER: <BR>
2000 - Carefully take the front panel off that surrounds the radio and temperature buttons, it will snap straight out. Wiggle the radio out about two inches, it is a tight fit. Get the serial number off the radio. It is on a sticker on the top, left side. Call a Mitsubishi dealer with the serial number. They will want proof of ownership, so have the title ready. After putting in the four digit serial number, hit the cd button and that enters it.The code is also written on an antitheft card that comes with the car and may be written in the owners manual in one of the back pages.
<BR> 1999 - Carefully remove the cup holder by pulling it out, then you will see the sticker with the radio serial number.
<BR> Other Years - I don't know an easy way to get the radio serial number, find a radio install savy person and ask them to help you. My dealership said they would do it for me and charge me for 30-60 mins worth of labor.. (At $75/hour) <BR> <BR>
RADIO SAYS "OFF" OR "LOCK": <BR>
Leave the "off" display on for 1 hour uninterupted, then it will automatically reset back to UNLOCK CODE.
<BR> When you turn it back on again after that time has passed it will ask for "code". <BR> <BR>
RADIO SAYS "UNLOCK CODE:" <BR>
Call your local MItsubishi dealership and ask for the service department.
<BR>They have a computer program where they punch in the serial number from your radio (you have to supply the number) and it will tell them the UNLOCK CODE for your radio. My dealership offered to give it to me free over the phone, if I knew my radio serial number. Enter the code using the buttons on your radio. And write the code down, this will show up everytime your radio looses connection to its power source - the car battery.
2helpful
Entering the radio code
The 1-4 buttons on your station preset are used to input the numbers. The one is the first number, the 2 is the second number, etc. Once you have the entered the 4 digit code, you have to push the tape button. If the code is correct, your normal display show.
2answers
Radio code
If you don't have the radios security code, you can try entering 1111 as some replacement radios were coded with this security code. Your local Audi Dealer may be able to provide the correct security code for your vehicle, if you provide them with your vehicles Identification Number (VIN). This VIN is typically located on the drivers door pillar.
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
To enter the code on the Wiesbaden Radio: Turn on the radio, SAFE should be displayed.
Push and hold the AM/FM button, then while holding the AM button down, push and hold down the SCAN button. Release the AM/FM and SCAN buttons, and the display should show 1000. Now enter the correct code using the radio pre-set station buttons (1-4). Button 1 changes the first digit in the code "1"000, Button 2 changes the second digit in the code 1"0"00, button 3 changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the AM/FM button, then while holding down the AM/FM button, push and hold down the SCAN button. The display will then show SAFE, release the two buttons, and now the radio should play correctly.
2helpful
3answers
Fix cd player in my car
disconnect battery and then try to re-enter code, then press cd on radio
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
