E1 is showing in display and belt won't turn
Manual :)
http://download.dfxi.com/supportdocs/AM_OM/Bowflex/BFX_TC5300_6000_OM_AM_RevA_web.pdf
U wld be able to look at diff. troubleshoot answers as well....
and if u want to knw regading the details :0
http://www.treadmilldoctor.com/Troublesh...
Most likely a problem with the motor control board.
check out the link
treadmilldoctor.com
E1 IS AN ASSEMBLY PROBLEM, TRY TO REASSEMBLE THHE UNIT.
E1 is general error, you get E1 if the assembly is bad, or if the trip sensor need to be reset.
Call TreadClimber Representatives at
1-800-NAUTILUS (1-800-628-8458).
They will follow you through resetting the unit.
Alternatively follow procedure from page 60 onward (61 on PDF) on the manual below:
Bowflex TreadClimber Assembly Guide and Owner’s Manual
ERR
1 - Motor Movement
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
Clean the s.speed , test for open or faulty-see the diagram for adjust. tight the connector very well.
God bless you
