The thinbg runs, but stops for a half second, then starts again, but it keeps it from getting more than lukewarm. after 30 mins clothes just as damp...help!
Dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
SOURCE: My Miele Touchtronic T 9800 Dryer progrma works
Hi dear.Try this,that should help you to solve the problem.If you need to download the user manual please click the link below.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T9802_us.pdf
Problem:The laundry is still wet. The program runs too long.
Solution:The air flow is insufficient. Check the lint filter, air intake and vent for obstructions(REFER USER MANUAL)
